[Nek5000-users] NEKTON and Gambit
Sat May 22 13:37:47 CDT 2010
Yes I am out of the country at the moment but can pass along the code when I get back (in a week).
And yes Gambit has an export format for Nekton but I couldn ´t make sense of it. I used a portion of matlab code Paul had written awhile back that writes the REA format, the rest of the code simply extracts information from the Generic Mesh file (Neutral file . neu ) exported from Gambit and prepares it to write the REA.
I´ll post the code when I return and try to include some explanation of how to get started with it. I included lots of comments so it should be straight forward.
Until then,
Michael M
----- Mensaje original -----
De: nek5000-users at lists. mcs . anl .gov
Para: nek5000-users at lists. mcs . anl .gov
Enviados : Viernes , 21 de Mayo 2010 14:21:20 GMT -05:00 Colombia
Asunto : Re: [Nek5000-users] NEKTON and Gambit
Hi Josh,
Yes, I recall that. For sure, I'd be grateful if you could let him know
that he has an eager customer for his program.
Cheers,
Frank
On Fri, 2010-05-21 at 19:09 +0000, nek5000-users at lists. mcs . anl .gov
wrote:
> Hey Frank,
> One of my colleagues, Michael, posted a method a while back that lists the steps to do something like this. It involves exporting the mesh from Gambit to the neutral file format ( NEU ) and then using a matlab program to convert the mesh to a usable REA file.
> I can't go into more detail than that as I wasn't the one to write the Matlab program, but I'm sure he wouldn't mind passing the Matlab file along again when he gets back to campus. Hope this helps,
> - Josh
> -----Original Message-----
> From: nek5000-users at lists. mcs . anl .gov
> Date: Fri, 21 May 2010 18:39:51
> To: <nek5000-users at lists. mcs . anl .gov>
> Subject: [Nek5000-users] NEKTON and Gambit
> Hello all,
> I notice that Fluent's grid generator Gambit writes out meshes in NEKTON
> format. However, from looking at the ( ASCI ) file it write out, it
> doesn't seem to be related to the structure the NEK5000 is expecting.
> Does anyone know if it is at all possible to get a mesh from Gambit into
> a format that NEK5000 can use?
> Cheers,
> Frank
Frank Herbert Muldoon , Ph .D. Mechanical Engineering
Technische Universität Wien (Technical University of Vienna)
Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
Mechanics and Heat Transfer)
Resselgasse 3
1040 Wien
Tel: +4315880132232
Fax: +4315880132299
Cell:+436765203470
fmuldoo ( skype )
http ://tetra.fluid. tuwien .ac.at/ fmuldoo / public_html / webpage /frank-muldoon. html
Nek5000-users mailing list
Nek5000-users at lists. mcs . anl .gov
https ://lists. mcs . anl .gov/mailman/ listinfo /nek5000-users
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100522/11efaf32/attachment.html>
