[Nek5000-users] [*] Re: [*] Re: Visit messing up
Thu May 20 07:06:03 CDT 2010
Thank you Stefan. I checked and indeed the coordinates switch was "F".
On 05/20/2010 04:51 PM, nek5000-users at lists.mcs.anl.gov wrote:
> The OUTPUT section in the rea-files controls what data will be dumped into a fld-file.
> So if you want to dump the coordinates just set:
>    ***** OUTPUT FIELD SPECIFICATION *****
>             X SPECIFICATIONS FOLLOW
>    T      COORDINATES
> Sometimes you don't want to dump the coordinates at every I/O step (to save space). In this case we the following in usrchk():
>        ifxyo = .true. ! Turn on xyz output
>        if (istep.gt.iostep) ifxyo = .false.  ! Turn off xyz output after first dump
> hth,
> Stefan
> On May 20, 2010, at 11:59 AM, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Stefan,
>>     Thanks for diagnosing the problem. Yes, the output is of high_ray0.f0001. No wonder, this always happens when I put the "firsttimestep" to something other than 1. So is there some switch that controls the output of coordinates?
>> Thanks,
>> Mani chandra
>> On 05/20/2010 03:05 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>> The problem might be something else!
>>> We assume that the first fld-file loaded into VisIt comes with mesh-coordinates.
>>> If the coordinates are missing you'll get a similar behavior.
>>> Stefan
>>> Sometimes it happens that users don't have
>>> On May 20, 2010, at 11:28 AM, nek5000-users at lists.mcs.anl.gov wrote:
>>>> Hello Mani,
>>>> Switch to the latest (2.0.0) Visit version.  There was a problem in
>>>> older versions (at least on 32 bit machines) that is now fixed.
>>>> Cheers,
>>>> Frank
>>>> On Thu, 2010-05-20 at 14:49 +0530, nek5000-users at lists.mcs.anl.gov
>>>> wrote:
>>>>> Hi,
>>>>>      Sometimes, randomly visit messes up the visualization, as shown in
>>>>> the attached picture. The mesh is supposed to be that of a 3D box.
>>>>> Reloading the database does not work. The simulation seems to be going
>>>>> ok and nek is running fine. I'm using Visit 1.12.2 svn revision 9638 and
>>>>> nek svn revision 518. Any clue as to why this is happening?
>>>>> Thanks,
>>>>> Mani chandra
>>>>> _______________________________________________
>>>>> Nek5000-users mailing list
>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>>> Frank Herbert Muldoon, Ph.D. Mechanical Engineering
>>>> Technische Universität Wien (Technical University of Vienna)
>>>> Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
>>>> Mechanics and Heat Transfer)
>>>> Resselgasse 3
>>>> 1040 Wien
>>>> Tel: +4315880132232
>>>> Fax: +4315880132299
>>>> Cell:+436765203470
>>>> fmuldoo (skype)
>>>> http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
