[Nek5000-users] [*] Re: Visit messing up
Thu May 20 04:59:50 CDT 2010
Hi Stefan,
     Thanks for diagnosing the problem. Yes, the output is of
high_ray0.f0001. No wonder, this always happens when I put the
"firsttimestep" to something other than 1. So is there some switch that
controls the output of coordinates?
Mani chandra
On 05/20/2010 03:05 PM, nek5000-users at lists.mcs.anl.gov wrote:
> The problem might be something else!
> We assume that the first fld-file loaded into VisIt comes with mesh-coordinates.
> If the coordinates are missing you'll get a similar behavior.
> Stefan
> Sometimes it happens that users don't have
> On May 20, 2010, at 11:28 AM, nek5000-users at lists.mcs.anl.gov wrote:
>> Hello Mani,
>> Switch to the latest (2.0.0) Visit version.  There was a problem in
>> older versions (at least on 32 bit machines) that is now fixed.
>> Cheers,
>> Frank
>> On Thu, 2010-05-20 at 14:49 +0530, nek5000-users at lists.mcs.anl.gov
>> wrote:
>>> Hi,
>>>      Sometimes, randomly visit messes up the visualization, as shown in
>>> the attached picture. The mesh is supposed to be that of a 3D box.
>>> Reloading the database does not work. The simulation seems to be going
>>> ok and nek is running fine. I'm using Visit 1.12.2 svn revision 9638 and
>>> nek svn revision 518. Any clue as to why this is happening?
>>> Thanks,
>>> Mani chandra
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>> Frank Herbert Muldoon, Ph.D. Mechanical Engineering
>> Technische Universität Wien (Technical University of Vienna)
>> Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
>> Mechanics and Heat Transfer)
>> Resselgasse 3
>> 1040 Wien
>> Tel: +4315880132232
>> Fax: +4315880132299
>> Cell:+436765203470
>> fmuldoo (skype)
>> http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
