[Nek5000-users] Visit messing up
Thu May 20 04:35:48 CDT 2010
The problem might be something else!
We assume that the first fld-file loaded into VisIt comes with mesh-coordinates.
If the coordinates are missing you'll get a similar behavior.
Stefan
Sometimes it happens that users don't have
On May 20, 2010, at 11:28 AM, nek5000-users at lists.mcs.anl.gov wrote:
> Hello Mani,
> Switch to the latest (2.0.0) Visit version.  There was a problem in
> older versions (at least on 32 bit machines) that is now fixed.
> Cheers,
> Frank
> On Thu, 2010-05-20 at 14:49 +0530, nek5000-users at lists.mcs.anl.gov
> wrote:
>> Hi,
>>     Sometimes, randomly visit messes up the visualization, as shown in
>> the attached picture. The mesh is supposed to be that of a 3D box.
>> Reloading the database does not work. The simulation seems to be going
>> ok and nek is running fine. I'm using Visit 1.12.2 svn revision 9638 and
>> nek svn revision 518. Any clue as to why this is happening?
>> Thanks,
>> Mani chandra
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> Frank Herbert Muldoon, Ph.D. Mechanical Engineering
> Technische Universität Wien (Technical University of Vienna)
> Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
> Mechanics and Heat Transfer)
> Resselgasse 3
> 1040 Wien
> Tel: +4315880132232
> Fax: +4315880132299
> Cell:+436765203470
> fmuldoo (skype)
> http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
