[Nek5000-users] [*] Re: interpolation example does not work
Tue May 18 23:36:40 CDT 2010
Thank you Stefan.
Mani chandra
On 05/18/2010 11:38 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Mani,
> I just updated the repo and the Wiki. Why don't you give it a whirl.
> Stefan
> On May 18, 2010, at 7:28 PM, nek5000-users at lists.mcs.anl.gov wrote:
>> Mani,
>> yes, the API of the interpolation routines have changed and I am in the process to update the Wiki etc.
>> Hang on
>> Stefan
>>> Hi,
>>>    The interpolation example given in the wiki gives a segmentation fault. A debugger reveals that the function as defined in postpro.f takes in 9 arguments whereas in the example, only 7 are given. What should be the last two arguments?
>>> The debug report is reproduced below:
>>> Program received signal SIGSEGV, Segmentation fault.
>>> 0x00000000005453fa in intpts (fieldin=..., nfld=2, itl=..., mi=4, rtl=..., mr=7, n=1, iffind=Cannot access memory at address 0x100000001
>>> ) at /home/mc/nek5_svn/trunk/nek/postpro.f:436
>>> 436           subroutine intpts(fieldin,nfld,iTl,mi,rTl,mr,n,iffind,ih)
>>> Thanks,
>>> Mani chandra
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
