[Nek5000-users] interpolation example does not work
Tue May 18 13:17:34 CDT 2010
Note hpts() will replace at some point the old history point stuff but some additional work is needed. For the moment the pressure is not automatically mapped but the following should work:
call prepost_map(0)
call hpts()
call prepost_map(1)
Later on, we call hpts() in prepost() where we map the pressure anyway.
hth,
Stefan
On May 18, 2010, at 8:08 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Mani,
> I just updated the repo and the Wiki. Why don't you give it a whirl.
> Stefan
> On May 18, 2010, at 7:28 PM, nek5000-users at lists.mcs.anl.gov wrote:
>> Mani,
>> yes, the API of the interpolation routines have changed and I am in the process to update the Wiki etc.
>> Hang on
>> Stefan
>>> Hi,
>>>  The interpolation example given in the wiki gives a segmentation fault. A debugger reveals that the function as defined in postpro.f takes in 9 arguments whereas in the example, only 7 are given. What should be the last two arguments?
>>> The debug report is reproduced below:
>>> Program received signal SIGSEGV, Segmentation fault.
>>> 0x00000000005453fa in intpts (fieldin=..., nfld=2, itl=..., mi=4, rtl=..., mr=7, n=1, iffind=Cannot access memory at address 0x100000001
>>> ) at /home/mc/nek5_svn/trunk/nek/postpro.f:436
>>> 436           subroutine intpts(fieldin,nfld,iTl,mi,rTl,mr,n,iffind,ih)
>>> Thanks,
>>> Mani chandra
>>> _______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
