[Nek5000-users] interpolation example does not work
Tue May 18 13:08:37 CDT 2010
Mani,
I just updated the repo and the Wiki. Why don't you give it a whirl.
Stefan
On May 18, 2010, at 7:28 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Mani,
> yes, the API of the interpolation routines have changed and I am in the process to update the Wiki etc.
> Hang on
> Stefan
>> Hi,
>>   The interpolation example given in the wiki gives a segmentation fault. A debugger reveals that the function as defined in postpro.f takes in 9 arguments whereas in the example, only 7 are given. What should be the last two arguments?
>> The debug report is reproduced below:
>> Program received signal SIGSEGV, Segmentation fault.
>> 0x00000000005453fa in intpts (fieldin=..., nfld=2, itl=..., mi=4, rtl=..., mr=7, n=1, iffind=Cannot access memory at address 0x100000001
>> ) at /home/mc/nek5_svn/trunk/nek/postpro.f:436
>> 436           subroutine intpts(fieldin,nfld,iTl,mi,rTl,mr,n,iffind,ih)
>> Thanks,
>> Mani chandra
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
