[Nek5000-users] interpolation example does not work
Tue May 18 12:28:27 CDT 2010
Mani,
yes, the API of the interpolation routines have changed and I am in the process to update the Wiki etc.
Hang on
Stefan
On May 18, 2010, at 7:28 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi,
>    The interpolation example given in the wiki gives a segmentation fault. A debugger reveals that the function as defined in postpro.f takes in 9 arguments whereas in the example, only 7 are given. What should be the last two arguments?
> The debug report is reproduced below:
> Program received signal SIGSEGV, Segmentation fault.
> 0x00000000005453fa in intpts (fieldin=..., nfld=2, itl=..., mi=4, rtl=..., mr=7, n=1, iffind=Cannot access memory at address 0x100000001
> ) at /home/mc/nek5_svn/trunk/nek/postpro.f:436
> 436           subroutine intpts(fieldin,nfld,iTl,mi,rTl,mr,n,iffind,ih)
> Thanks,
> Mani chandra
> Nek5000-users mailing list
