[Nek5000-users] interpolation example does not work
Tue May 18 12:28:16 CDT 2010
     The interpolation example given in the wiki gives a segmentation
fault. A debugger reveals that the function as defined in postpro.f
takes in 9 arguments whereas in the example, only 7 are given. What
should be the last two arguments?
The debug report is reproduced below:
Program received signal SIGSEGV, Segmentation fault.
0x00000000005453fa in intpts (fieldin=..., nfld=2, itl=..., mi=4,
rtl=..., mr=7, n=1, iffind=Cannot access memory at address 0x100000001
) at /home/mc/nek5_svn/trunk/nek/postpro.f:436
436           subroutine intpts(fieldin,nfld,iTl,mi,rTl,mr,n,iffind,ih)
Mani chandra
