[Nek5000-users] Hpts subroutine
Tue May 18 10:52:05 CDT 2010
Yes you're right this is a bug. I just coded that up very quickly and haven't had the time to check it. I will fix it and add support for pressure.
Stefan
On May 18, 2010, at 5:41 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Hello,
> This email is in regards to the hpts subroutine that was added to the repo 513 and subsequent versions.
> A part of the code snippet from postpro.f ( subroutine hpts ) is pasted below :
> <code>
>       call copy(wrk(1,1,1,1,2),vy,ntot)
>       if(if3d) call copy(wrk(1,1,1,1,2),vz,ntot)
> </code>
> could the second line be " if(if3d) call copy(wrk(1,1,1,1,3),vz,ntot) " else vz would then be overwritten over vy ?
> Along the same lines, I would like to know what one would have to change to output the pressure values as well.
> Thanks
> Shriram
> Nek5000-users mailing list
