[Nek5000-users] New code+recycling BC
Tue May 11 08:16:28 CDT 2010
thanks for the update. I looked at the jet example and can't quite
figure out what to change such that my case works with the new code.
My domain has a box consisting of 9 elements in the "periodic"
x-direction, 12 elements in y and 8 elements in z. The inflow is the y/z
plane.
The numbering is such that the first periodic slab is from element 1
(inflow) to 9, then 10 to 19, ... 12 times (in y) to 100-108. Then all
other elements (the "non-periodic" part) follow, which are a total of
444 per x/y plane. Thus, the next 12 slabs (at the second level in z)
would start with 445-453, 454-462, ...12 times, and so forth.
Here is the part that is giving me trouble, since I don't know what to
assign for n_in_pipe and ne_per_slab.
c     Connect slab next to the last with inflow (recycling method)
       if(istep.eq.0) then
         call izero(glo_num,n)
         do e=1,nelv
            eg = lglel(e)
            if (eg.le.n_in_pipe) then
               do j=1,nx1*ny1             ! Only on FACE 5 (inflow)
                  iloc          = j + nxyz*(e -1)
                  glo_num(iloc) = j + nxyz*(eg-1)
                  ieshift       = eg + (nslab-1)*ne_per_slab
                  ishift        = j + nxyz*(ieshift-1)
                  if (eg.le.ne_per_slab) glo_num(iloc) = ishift
               enddo
            endif
         enddo
         call gs_setup(gs_bc_hndl,glo_num,n,nekcomm,mp)
       endif
Markus
nek5000-users at lists.mcs.anl.gov wrote:
> Hi Markus,
> yes we changed glo_num to be an 8-byte integer array. Unfortunately we did not update the examples. I'll update the turbJet example.
> Stefan
> On May 5, 2010, at 12:39 AM, nek5000-users at lists.mcs.anl.gov wrote:
>> Hiu,
>> sorry about the delay, to make sure I regenerated the problem.
>> I did as you suggested, it is still messed up when opening the first fld dump in
>> VisIt with the meta file containing only one file.
>> What I meant by element ordering is the way the recycling b.c. is set up, where
>> the "outflow" face of recycling box is established by counting a number of
>> elements downstream from the inflow, as it is done in the jet example. I have a
>> suspicion that something changed there (not in my .rea file, though).
>> The problem came about when updating Nek from 404 to 503, I did not change
>> Visit.
>> Thanks,
>> Markus
>> Quoting nek5000-users at lists.mcs.anl.gov:
>>> Can you dump a field file including the geometry and then visualize it using
>>> VisIt (your metadata file should only contain one single fld). Is it still
>>> messed up?
>>> Stefan
>>> On May 3, 2010, at 5:24 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>> Markus,
>>>> is it only a viz issue or do you have some problems in Nek after upgrading
>>> to the latest release.
>>>> Stefan
>>>> On May 3, 2010, at 4:25 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>> Hi,
>>>>> when updating the code from rev. 404 (oldvel.png) to 503
>>>>> (newvel.png), I realized a problem with the recycling
>>>>> (periodic) boundary condition for a channel simulation I am doing -
>>>>> compare the attached pictures of velocity on the inflow plane (the inflow
>>> is the Y/Z plane). For the two cases, SIZE/SIZEu, .rea, the restart step and
>>> .usr are the exact same.
>>>>> Here are the relevant pieces from .usr. Have any of the functions
>>>>> changed or am I doing something wrong? It seems as if the element
>>>>> ordering is not what it was before.
>>>>> I did this based on the jet example.
>>>>> Thanks,
>>>>> Markus
>>>>> c-----------------------------------------------------------------------
>>>>>     subroutine userbc (ix,iy,iz,iside,eg)
>>>>>     include 'SIZE'
>>>>>     include 'TOTAL'
>>>>>     include 'NEKUSE'
>>>>>     common /cvelbc/ uin(lx1,ly1,lz1,lelv)
>>>>>    $              , vin(lx1,ly1,lz1,lelv)
>>>>>    $              , win(lx1,ly1,lz1,lelv)
>>>>>    $              , tin(lx1,ly1,lz1,lelv)
>>>>>     integer e,eg
>>>>>     e = gllel(eg)
>>>>>     ux=uin(ix,iy,iz,e)
>>>>>     uy=vin(ix,iy,iz,e)
>>>>>     uz=win(ix,iy,iz,e)
>>>>>     subroutine userchk
>>>>>     include 'SIZE'
>>>>>     include 'TOTAL'
>>>>>     include 'ZPER'  ! for nelx,nely,nelz
>>>>>     include 'RESTART' !Needs to be here for prepost to work
>>>>>     common /cvlmsk/ vlmsk(lx1,ly1,lz1,lelt),vvol,
>>>>>    &                wt(lx1*ly1*lz1,lelt),vol_per
>>>>>     integer e,f,eg,ninx,niny,ninz
>>>>> .c-----Computations for recycling BC
>>>>>     speed = glsc2(vx,wt,n)/vol_per ! Where vol_per is the volume of
>>>>> the recycling box
>>>>>     starg = 1.0
>>>>>     addtemp = 1.0
>>>>>     call set_inflow(starg,speed,addtemp)   ! set up inflow BCs
>>>>>     subroutine set_inflow(starg,speed,addtemp)   ! set up inflow BCs
>>>>>     include 'SIZE'
>>>>>     include 'TOTAL'
>>>>>     integer icalld,e,eg,f
>>>>>     save    icalld
>>>>>     data    icalld /0/
>>>>>     common /scruz/  ptr(lx1,ly1,lz1,lelv)
>>>>>     integer ptr,gs_bc_hndl
>>>>>     save        gs_bc_hndl
>>>>>     real ratio
>>>>>     save ratio
>>>>>     data ratio / 1. /
>>>>>     common /nekmpi/ mid,mp,nekcomm,nekgroup,nekreal
>>>>>     n = nx1*ny1*nz1*nelv
>>>>>     if (icalld.eq.0) then
>>>>>        icalld = 1
>>>>>        nxyz = nx1*ny1*nz1
>>>>>        do e=1,nelv
>>>>>           eg = lglel(e)
>>>>>           eo = nxyz*(eg-1)    ! offset
>>>>>           do i=1,nxyz
>>>>>              ptr(i,1,1,e) = i+eo
>>>>>           enddo
>>>>>           do k=2,nz1-1        ! get rid of interior pointers
>>>>>           do j=2,ny1-1            do i=2,nx1-1
>>>>>              ptr(i,j,k,e) = 0
>>>>>           enddo
>>>>>           enddo
>>>>>           enddo
>>>>>           nface = 2*ndim
>>>>>           do f=1,nface        ! connect inflow to elems downstream
>>>>>              ioff = nxyz*8    ! 5 elements in X to end of "periodic" sec.
>>>>>              if (cbc(f,e,1).eq.'v  ') then
>>>>>                call iface_add(ptr,f,e,ioff,nx1,ny1,nz1)
>>>>>              endif
>>>>>           enddo
>>>>>        enddo
>>>>>        call gs_setup(gs_bc_hndl,ptr,n,nekcomm,np) ! connect v +
>>>>> downstream
>>>>>     endif
>>>>>     call copy(uin,vx,n)
>>>>>     call copy(vin,vy,n)
>>>>>     call copy(win,vz,n)
>>>>>     call copy(tin,t,n)
>>>>>     call col2(uin,v1mask,n)
>>>>>     call col2(vin,v2mask,n)
>>>>>     call col2(win,v3mask,n)
>>>>>     call col2(tin,tmask,n)
>>>>>     call gs_op(gs_bc_hndl,uin,1,1,0)  ! 1 ==> +  ! uin(inflow) =
>>>>> vx(slab_k)
>>>>>     call gs_op(gs_bc_hndl,vin,1,1,0)  ! 1 ==> +
>>>>>     call gs_op(gs_bc_hndl,win,1,1,0)  ! 1 ==> +
>>>>>     call gs_op(gs_bc_hndl,tin,1,1,0)  ! 1 ==> +
>>>>>     if (speed.gt.0) then
>>>>>        ratio = .5*(starg/speed + ratio)
>>>>>        call cmult(uin,ratio,n)
>>>>>        call cmult(vin,ratio,n)
>>>>>        call cmult(win,ratio,n)
>>>>>        call cadd(tin,addtemp,n) !Substract added heat
>>>>>     endif
>>>>>     return
>>>>>     end
>>>>> <oldvel.png><newvel.png>_______________________________________________
>>>>> Nek5000-users mailing list
>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
