[Nek5000-users] New code+recycling BC
Tue May 11 09:15:00 CDT 2010
Hi Markus,
we only changed glo_num to be an 8-byte integer. That's it!
Stefan
On May 11, 2010, at 3:16 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi,
> thanks for the update. I looked at the jet example and can't quite figure out what to change such that my case works with the new code.
> My domain has a box consisting of 9 elements in the "periodic" x-direction, 12 elements in y and 8 elements in z. The inflow is the y/z plane.
> The numbering is such that the first periodic slab is from element 1 (inflow) to 9, then 10 to 19, ... 12 times (in y) to 100-108. Then all other elements (the "non-periodic" part) follow, which are a total of 444 per x/y plane. Thus, the next 12 slabs (at the second level in z) would start with 445-453, 454-462, ...12 times, and so forth.
> Here is the part that is giving me trouble, since I don't know what to assign for n_in_pipe and ne_per_slab.
> c     Connect slab next to the last with inflow (recycling method)
>      if(istep.eq.0) then
>        call izero(glo_num,n)
>        do e=1,nelv
>           eg = lglel(e)
>           if (eg.le.n_in_pipe) then
>              do j=1,nx1*ny1             ! Only on FACE 5 (inflow)
>                 iloc          = j + nxyz*(e -1)
>                 glo_num(iloc) = j + nxyz*(eg-1)
>                 ieshift       = eg + (nslab-1)*ne_per_slab
>                 ishift        = j + nxyz*(ieshift-1)
>                 if (eg.le.ne_per_slab) glo_num(iloc) = ishift
>              enddo
>           endif
>        enddo
>        call gs_setup(gs_bc_hndl,glo_num,n,nekcomm,mp)
>      endif
> Thanks,
> Markus
>> Hi Markus,
>> yes we changed glo_num to be an 8-byte integer array. Unfortunately we did not update the examples. I'll update the turbJet example.
>> Stefan
>> On May 5, 2010, at 12:39 AM, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hiu,
>>> sorry about the delay, to make sure I regenerated the problem.
>>> I did as you suggested, it is still messed up when opening the first fld dump in
>>> VisIt with the meta file containing only one file.
>>> What I meant by element ordering is the way the recycling b.c. is set up, where
>>> the "outflow" face of recycling box is established by counting a number of
>>> elements downstream from the inflow, as it is done in the jet example. I have a
>>> suspicion that something changed there (not in my .rea file, though).
>>> The problem came about when updating Nek from 404 to 503, I did not change
>>> Visit.
>>> Thanks,
>>> Markus
>>> Quoting nek5000-users at lists.mcs.anl.gov:
>>>> Can you dump a field file including the geometry and then visualize it using
>>>> VisIt (your metadata file should only contain one single fld). Is it still
>>>> messed up?
>>>> Stefan
>>>> On May 3, 2010, at 5:24 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>> Markus,
>>>>> is it only a viz issue or do you have some problems in Nek after upgrading
>>>> to the latest release.
>>>>> Stefan
>>>>> On May 3, 2010, at 4:25 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>> Hi,
>>>>>> when updating the code from rev. 404 (oldvel.png) to 503
>>>>>> (newvel.png), I realized a problem with the recycling
>>>>>> (periodic) boundary condition for a channel simulation I am doing -
>>>>>> compare the attached pictures of velocity on the inflow plane (the inflow
>>>> is the Y/Z plane). For the two cases, SIZE/SIZEu, .rea, the restart step and
>>>> .usr are the exact same.
>>>>>> Here are the relevant pieces from .usr. Have any of the functions
>>>>>> changed or am I doing something wrong? It seems as if the element
>>>>>> ordering is not what it was before.
>>>>>> I did this based on the jet example.
>>>>>> Thanks,
>>>>>> Markus
>>>>>> c-----------------------------------------------------------------------
>>>>>>    subroutine userbc (ix,iy,iz,iside,eg)
>>>>>>    include 'SIZE'
>>>>>>    include 'TOTAL'
>>>>>>    include 'NEKUSE'
>>>>>>    common /cvelbc/ uin(lx1,ly1,lz1,lelv)
>>>>>>   $              , vin(lx1,ly1,lz1,lelv)
>>>>>>   $              , win(lx1,ly1,lz1,lelv)
>>>>>>   $              , tin(lx1,ly1,lz1,lelv)
>>>>>>    integer e,eg
>>>>>>    e = gllel(eg)
>>>>>>    ux=uin(ix,iy,iz,e)
>>>>>>    uy=vin(ix,iy,iz,e)
>>>>>>    uz=win(ix,iy,iz,e)
>>>>>>    subroutine userchk
>>>>>>    include 'SIZE'
>>>>>>    include 'TOTAL'
>>>>>>    include 'ZPER'  ! for nelx,nely,nelz
>>>>>>    include 'RESTART' !Needs to be here for prepost to work
>>>>>>    common /cvlmsk/ vlmsk(lx1,ly1,lz1,lelt),vvol,
>>>>>>   &                wt(lx1*ly1*lz1,lelt),vol_per
>>>>>>    integer e,f,eg,ninx,niny,ninz
>>>>>> .c-----Computations for recycling BC
>>>>>>    speed = glsc2(vx,wt,n)/vol_per ! Where vol_per is the volume of
>>>>>> the recycling box
>>>>>>    starg = 1.0
>>>>>>    addtemp = 1.0
>>>>>>    call set_inflow(starg,speed,addtemp)   ! set up inflow BCs
>>>>>>    subroutine set_inflow(starg,speed,addtemp)   ! set up inflow BCs
>>>>>>    include 'SIZE'
>>>>>>    include 'TOTAL'
>>>>>>    integer icalld,e,eg,f
>>>>>>    save    icalld
>>>>>>    data    icalld /0/
>>>>>>    common /scruz/  ptr(lx1,ly1,lz1,lelv)
>>>>>>    integer ptr,gs_bc_hndl
>>>>>>    save        gs_bc_hndl
>>>>>>    real ratio
>>>>>>    save ratio
>>>>>>    data ratio / 1. /
>>>>>>    common /nekmpi/ mid,mp,nekcomm,nekgroup,nekreal
>>>>>>    n = nx1*ny1*nz1*nelv
>>>>>>    if (icalld.eq.0) then
>>>>>>       icalld = 1
>>>>>>       nxyz = nx1*ny1*nz1
>>>>>>       do e=1,nelv
>>>>>>          eg = lglel(e)
>>>>>>          eo = nxyz*(eg-1)    ! offset
>>>>>>          do i=1,nxyz
>>>>>>             ptr(i,1,1,e) = i+eo
>>>>>>          enddo
>>>>>>          do k=2,nz1-1        ! get rid of interior pointers
>>>>>>          do j=2,ny1-1            do i=2,nx1-1
>>>>>>             ptr(i,j,k,e) = 0
>>>>>>          enddo
>>>>>>          enddo
>>>>>>          enddo
>>>>>>          nface = 2*ndim
>>>>>>          do f=1,nface        ! connect inflow to elems downstream
>>>>>>             ioff = nxyz*8    ! 5 elements in X to end of "periodic" sec.
>>>>>>             if (cbc(f,e,1).eq.'v  ') then
>>>>>>               call iface_add(ptr,f,e,ioff,nx1,ny1,nz1)
>>>>>>             endif
>>>>>>          enddo
>>>>>>       enddo
>>>>>>       call gs_setup(gs_bc_hndl,ptr,n,nekcomm,np) ! connect v +
>>>>>> downstream
>>>>>>    endif
>>>>>>    call copy(uin,vx,n)
>>>>>>    call copy(vin,vy,n)
>>>>>>    call copy(win,vz,n)
>>>>>>    call copy(tin,t,n)
>>>>>>    call col2(uin,v1mask,n)
>>>>>>    call col2(vin,v2mask,n)
>>>>>>    call col2(win,v3mask,n)
>>>>>>    call col2(tin,tmask,n)
>>>>>>    call gs_op(gs_bc_hndl,uin,1,1,0)  ! 1 ==> +  ! uin(inflow) =
>>>>>> vx(slab_k)
>>>>>>    call gs_op(gs_bc_hndl,vin,1,1,0)  ! 1 ==> +
>>>>>>    call gs_op(gs_bc_hndl,win,1,1,0)  ! 1 ==> +
>>>>>>    call gs_op(gs_bc_hndl,tin,1,1,0)  ! 1 ==> +
>>>>>>    if (speed.gt.0) then
>>>>>>       ratio = .5*(starg/speed + ratio)
>>>>>>       call cmult(uin,ratio,n)
>>>>>>       call cmult(vin,ratio,n)
>>>>>>       call cmult(win,ratio,n)
>>>>>>       call cadd(tin,addtemp,n) !Substract added heat
>>>>>>    endif
>>>>>>    return
>>>>>>    end
>>>>>> <oldvel.png><newvel.png>_______________________________________________
>>>>>> Nek5000-users mailing list
>>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
