[Nek5000-users] New code+recycling BC
Wed May 5 01:52:03 CDT 2010
Hi Markus,
yes we changed glo_num to be an 8-byte integer array. Unfortunately we did not update the examples. I'll update the turbJet example.
Stefan
On May 5, 2010, at 12:39 AM, nek5000-users at lists.mcs.anl.gov wrote:
> Hiu,
> sorry about the delay, to make sure I regenerated the problem.
> I did as you suggested, it is still messed up when opening the first fld dump in
> VisIt with the meta file containing only one file.
> What I meant by element ordering is the way the recycling b.c. is set up, where
> the "outflow" face of recycling box is established by counting a number of
> elements downstream from the inflow, as it is done in the jet example. I have a
> suspicion that something changed there (not in my .rea file, though).
> The problem came about when updating Nek from 404 to 503, I did not change
> Visit.
> Thanks,
> Markus
> Quoting nek5000-users at lists.mcs.anl.gov:
>> Can you dump a field file including the geometry and then visualize it using
>> VisIt (your metadata file should only contain one single fld). Is it still
>> messed up?
>> Stefan
>> On May 3, 2010, at 5:24 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>> Markus,
>>> is it only a viz issue or do you have some problems in Nek after upgrading
>> to the latest release.
>>> Stefan
>>> On May 3, 2010, at 4:25 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>> Hi,
>>>> when updating the code from rev. 404 (oldvel.png) to 503
>>>> (newvel.png), I realized a problem with the recycling
>>>> (periodic) boundary condition for a channel simulation I am doing -
>>>> compare the attached pictures of velocity on the inflow plane (the inflow
>> is the Y/Z plane). For the two cases, SIZE/SIZEu, .rea, the restart step and
>> .usr are the exact same.
>>>> Here are the relevant pieces from .usr. Have any of the functions
>>>> changed or am I doing something wrong? It seems as if the element
>>>> ordering is not what it was before.
>>>> I did this based on the jet example.
>>>> Thanks,
>>>> Markus
>>>> c-----------------------------------------------------------------------
>>>>     subroutine userbc (ix,iy,iz,iside,eg)
>>>>     include 'SIZE'
>>>>     include 'TOTAL'
>>>>     include 'NEKUSE'
>>>>     common /cvelbc/ uin(lx1,ly1,lz1,lelv)
>>>>    $              , vin(lx1,ly1,lz1,lelv)
>>>>    $              , win(lx1,ly1,lz1,lelv)
>>>>    $              , tin(lx1,ly1,lz1,lelv)
>>>>     integer e,eg
>>>>     e = gllel(eg)
>>>>     ux=uin(ix,iy,iz,e)
>>>>     uy=vin(ix,iy,iz,e)
>>>>     uz=win(ix,iy,iz,e)
>>>>     subroutine userchk
>>>>     include 'SIZE'
>>>>     include 'TOTAL'
>>>>     include 'ZPER'  ! for nelx,nely,nelz
>>>>     include 'RESTART' !Needs to be here for prepost to work
>>>>     common /cvlmsk/ vlmsk(lx1,ly1,lz1,lelt),vvol,
>>>>    &                wt(lx1*ly1*lz1,lelt),vol_per
>>>>     integer e,f,eg,ninx,niny,ninz
>>>> .c-----Computations for recycling BC
>>>>     speed = glsc2(vx,wt,n)/vol_per ! Where vol_per is the volume of
>>>> the recycling box
>>>>     starg = 1.0
>>>>     addtemp = 1.0
>>>>     call set_inflow(starg,speed,addtemp)   ! set up inflow BCs
>>>>     subroutine set_inflow(starg,speed,addtemp)   ! set up inflow BCs
>>>>     include 'SIZE'
>>>>     include 'TOTAL'
>>>>     integer icalld,e,eg,f
>>>>     save    icalld
>>>>     data    icalld /0/
>>>>     common /scruz/  ptr(lx1,ly1,lz1,lelv)
>>>>     integer ptr,gs_bc_hndl
>>>>     save        gs_bc_hndl
>>>>     real ratio
>>>>     save ratio
>>>>     data ratio / 1. /
>>>>     common /nekmpi/ mid,mp,nekcomm,nekgroup,nekreal
>>>>     n = nx1*ny1*nz1*nelv
>>>>     if (icalld.eq.0) then
>>>>        icalld = 1
>>>>        nxyz = nx1*ny1*nz1
>>>>        do e=1,nelv
>>>>           eg = lglel(e)
>>>>           eo = nxyz*(eg-1)    ! offset
>>>>           do i=1,nxyz
>>>>              ptr(i,1,1,e) = i+eo
>>>>           enddo
>>>>           do k=2,nz1-1        ! get rid of interior pointers
>>>>           do j=2,ny1-1            do i=2,nx1-1
>>>>              ptr(i,j,k,e) = 0
>>>>           enddo
>>>>           enddo
>>>>           enddo
>>>>           nface = 2*ndim
>>>>           do f=1,nface        ! connect inflow to elems downstream
>>>>              ioff = nxyz*8    ! 5 elements in X to end of "periodic" sec.
>>>>              if (cbc(f,e,1).eq.'v  ') then
>>>>                call iface_add(ptr,f,e,ioff,nx1,ny1,nz1)
>>>>              endif
>>>>           enddo
>>>>        enddo
>>>>        call gs_setup(gs_bc_hndl,ptr,n,nekcomm,np) ! connect v +
>>>> downstream
>>>>     endif
>>>>     call copy(uin,vx,n)
>>>>     call copy(vin,vy,n)
>>>>     call copy(win,vz,n)
>>>>     call copy(tin,t,n)
>>>>     call col2(uin,v1mask,n)
>>>>     call col2(vin,v2mask,n)
>>>>     call col2(win,v3mask,n)
>>>>     call col2(tin,tmask,n)
>>>>     call gs_op(gs_bc_hndl,uin,1,1,0)  ! 1 ==> +  ! uin(inflow) =
>>>> vx(slab_k)
>>>>     call gs_op(gs_bc_hndl,vin,1,1,0)  ! 1 ==> +
>>>>     call gs_op(gs_bc_hndl,win,1,1,0)  ! 1 ==> +
>>>>     call gs_op(gs_bc_hndl,tin,1,1,0)  ! 1 ==> +
>>>>     if (speed.gt.0) then
>>>>        ratio = .5*(starg/speed + ratio)
>>>>        call cmult(uin,ratio,n)
>>>>        call cmult(vin,ratio,n)
>>>>        call cmult(win,ratio,n)
>>>>        call cadd(tin,addtemp,n) !Substract added heat
>>>>     endif
>>>>     return
>>>>     end
>>>> <oldvel.png><newvel.png>_______________________________________________
>>>> Nek5000-users mailing list
>>>> Nek5000-users at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
