[Nek5000-users] Compilation failing with gfortran
Tue May 11 06:00:49 CDT 2010
What Nek version did you use before you changed to the latest release?
Stefan
On May 11, 2010, at 12:08 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi,
>    I'm using mpif77 with gfortran underneath and I'm not able to compile any of the examples of the latest code (which I downloaded today).
> The error is:
> /home/guest/nek5_svn/trunk/nek/navier8.f: In function 'setvert3d':
> /home/guest/nek5_svn/trunk/nek/navier8.f:2322: internal compiler error: in expand_expr_real_1, at expr.c:6846
> Please submit a full bug report,
> with preprocessed source if appropriate.
> See <URL:http://bugzilla.redhat.com/bugzilla> for instructions.
> make: *** [obj/navier8.o] Error 1
> However an earlier version of the code which I've been using for a couple of months works fine. Attached is the compiler.out. I've noticed that the input files are slightly different. Do we not need SESSION.NAME any more?
> Regards,
> Mani chandra
> <compiler.out>_______________________________________________
> Nek5000-users mailing list
