[Nek5000-users] [*] Re: Compilation failing with gfortran
Tue May 11 06:40:02 CDT 2010
     Good point. I checked with the latest version of gfortran and it
worked. Sorry for the bother.
Mani chandra
On 05/11/2010 04:01 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Hello Mani,
> An "internal compiler error" is just that, a problem concerning the
> compiler.  The right step is to submit a detailed bug report to them,
> after checking that it is repeatable with the latest gfortran.  They
> will fix such problems and sometimes do so quite quickly (from personal
> experience).  While doubtless there is a workaround that the developers
> could come up with, doing so would most likely be a improper use of
> their time.  The most efficient solution for all concerned is to fix the
> source of the error and not the symptom.
> Cheers,
> Frank
> On Tue, 2010-05-11 at 15:38 +0530, nek5000-users at lists.mcs.anl.gov
> wrote:
>> Hi,
>>       I'm using mpif77 with gfortran underneath and I'm not able to
>> compile any of the examples of the latest code (which I downloaded today).
>> The error is:
>> /home/guest/nek5_svn/trunk/nek/navier8.f: In function 'setvert3d':
>> /home/guest/nek5_svn/trunk/nek/navier8.f:2322: internal compiler error:
>> in expand_expr_real_1, at expr.c:6846
>> Please submit a full bug report,
>> with preprocessed source if appropriate.
>> See<URL:http://bugzilla.redhat.com/bugzilla>  for instructions.
>> make: *** [obj/navier8.o] Error 1
>> However an earlier version of the code which I've been using for a
>> couple of months works fine. Attached is the compiler.out. I've noticed
>> that the input files are slightly different. Do we not need SESSION.NAME
>> any more?
>> Regards,
>> Mani chandra
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
