[Nek5000-users] [*] Re: Compilation failing with gfortran
Tue May 11 06:18:19 CDT 2010
     I don't know the revision number but the one I was using did not
have the examples benard, conj_ht, fs_hydro, peris, rayleigh and shear4.
Is there someway I can get the revision number?
Mani chandra
On 05/11/2010 04:30 PM, nek5000-users at lists.mcs.anl.gov wrote:
> What Nek version did you use before you changed to the latest release?
> Stefan
> On May 11, 2010, at 12:08 PM, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi,
>>     I'm using mpif77 with gfortran underneath and I'm not able to compile any of the examples of the latest code (which I downloaded today).
>> The error is:
>> /home/guest/nek5_svn/trunk/nek/navier8.f: In function 'setvert3d':
>> /home/guest/nek5_svn/trunk/nek/navier8.f:2322: internal compiler error: in expand_expr_real_1, at expr.c:6846
>> Please submit a full bug report,
>> with preprocessed source if appropriate.
>> See<URL:http://bugzilla.redhat.com/bugzilla>  for instructions.
>> make: *** [obj/navier8.o] Error 1
>> However an earlier version of the code which I've been using for a couple of months works fine. Attached is the compiler.out. I've noticed that the input files are slightly different. Do we not need SESSION.NAME any more?
>> Regards,
>> Mani chandra
>> <compiler.out>_______________________________________________
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
