[Nek5000-users] prex & pretex not working
Mon May 3 09:38:41 CDT 2010
Can you try on another Linux box? You can get the Intel compilers (non commercial usage) for free.
Sorry I don't want to login into other machines unless it's really needed.
Stefan
On May 3, 2010, at 4:34 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Stefan,
> I do not have any other compiler on the cluster. I can give you my login
> to check the problem.
> Thanks,
> Harish.
> On Mon, 3 May 2010 nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Harish,
>> unfortunately I cannot reproduce the problem over there (gcc 4.2.1/ gfortran 4.5).
>> Can you try again using another compiler?
>> Stefan
>> On May 3, 2010, at 3:26 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>> Hello,
>>> I am compiling prenek with GNU compilers, gfortran-4.3.2 and gcc-4.3.2.
>>> When I compile it without "BIGMEM" flag it gives an error, the output of
>>> it is attached (error.out). With "BIGMEM" flag turned on, there are no
>>> compiler errors (compile.out). But when I try to open pretex or prex, I
>>> get the following error.
>>> [harish at cmtl hole-in-center]$ prex
>>> Killed
>>> [harish at cmtl hole-in-center]$ pretex
>>> Killed
>>> All the other tools are working fine. Any help in solving this issue is
>>> appreciated.
>>> Thanks,
>>> Harish.
>>> <error.out><compile.out>_______________________________________________
>>> Nek5000-users mailing list
>>> Nek5000-users at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
