[Nek5000-users] prex & pretex not working
Mon May 3 09:34:13 CDT 2010
Hi Stefan,
I do not have any other compiler on the cluster. I can give you my login
to check the problem.
Harish.
On Mon, 3 May 2010 nek5000-users at lists.mcs.anl.gov wrote:
> Hi Harish,
> unfortunately I cannot reproduce the problem over there (gcc 4.2.1/ gfortran 4.5).
> Can you try again using another compiler?
> Stefan
> On May 3, 2010, at 3:26 PM, nek5000-users at lists.mcs.anl.gov wrote:
> > Hello,
> > I am compiling prenek with GNU compilers, gfortran-4.3.2 and gcc-4.3.2.
> > When I compile it without "BIGMEM" flag it gives an error, the output of
> > it is attached (error.out). With "BIGMEM" flag turned on, there are no
> > compiler errors (compile.out). But when I try to open pretex or prex, I
> > get the following error.
> > [harish at cmtl hole-in-center]$ prex
> > Killed
> > [harish at cmtl hole-in-center]$ pretex
> > Killed
> > All the other tools are working fine. Any help in solving this issue is
> > appreciated.
> > Thanks,
> > Harish.
> > <error.out><compile.out>_______________________________________________
> > Nek5000-users mailing list
> > Nek5000-users at lists.mcs.anl.gov
> > https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
