[Nek5000-users] prex & pretex not working
Mon May 3 10:45:42 CDT 2010
Hi Stefan,
I tried compiling prenek on NCSA-Abe machine with ifort & icc. I get the
following error, its same error w/ and w/o "BIGMEM" flag.
Harish.
icc -c -DUNDERSCORE -Dr8 xdriver.c
xdriver.c(875): warning #266: function "fprep_" declared implicitly
      fprep_ ();      /* run Fortran Main code */
xdriver.c(123): (col. 5) remark: LOOP WAS VECTORIZED.
xdriver.c(125): (col. 5) remark: LOOP WAS VECTORIZED.
xdriver.c(869): (col. 5) remark: LOOP WAS VECTORIZED.
xdriver.c(747): (col. 4) remark: LOOP WAS VECTORIZED.
xdriver.c(823): (col. 4) remark: LOOP WAS VECTORIZED.
xdriver.c(700): (col. 5) remark: LOOP WAS VECTORIZED.
xdriver.c(333): (col. 5) remark: LOOP WAS VECTORIZED.
xdriver.c(340): (col. 5) remark: LOOP WAS VECTORIZED.
ifort -o /u/ac/kanch1/nek5_svn/trunk/tools/prex prenek.o curve.o edit.o
build.o build1.o build2.o bound.o plot.o xinterface.o glomod.o legend.o
vprops.o iolib.o subs.o zipper2.o postnek6.o screen.o revert.o crs.o mxm.o
xdriver.o  -L/usr/X11R6/lib64 -lX11 -lm
prenek.o(.text+0x47d): In function `drivfc_':
: relocation truncated to fit: R_X86_64_PC32 chaar_
prenek.o(.text+0x4f9): In function `drivfc_':
prenek.o(.text+0x50d): In function `drivfc_':
: relocation truncated to fit: R_X86_64_PC32 basics_
prenek.o(.text+0x584): In function `drivfc_':
: relocation truncated to fit: R_X86_64_PC32 devs_
prenek.o(.text+0x5b1): In function `drivfc_':
prenek.o(.text+0x62d): In function `drivfc_':
prenek.o(.text+0x667): In function `drivfc_':
: relocation truncated to fit: R_X86_64_32S chaar_
prenek.o(.text+0x740): In function `drivfc_':
: relocation truncated to fit: R_X86_64_PC32 modes_
prenek.o(.text+0x789): In function `drivfc_':
prenek.o(.text+0x7fc): In function `drivfc_':
prenek.o(.text+0x80c): In function `drivfc_':
: additional relocation overflows omitted from the output
make[1]: *** [prex] Error 1
make[1]: Leaving directory `/u/ac/kanch1/nek5_svn/trunk/tools/prenek'
make: *** [all] Error 1
On Mon, May 3, 2010 9:38 am, nek5000-users at lists.mcs.anl.gov wrote:
> Can you try on another Linux box? You can get the Intel compilers (non
> commercial usage) for free.
> Sorry I don't want to login into other machines unless it's really needed.
> Stefan
> On May 3, 2010, at 4:34 PM, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Stefan,
>> I do not have any other compiler on the cluster. I can give you my login
>> to check the problem.
>> Thanks,
>> Harish.
>> On Mon, 3 May 2010 nek5000-users at lists.mcs.anl.gov wrote:
>>> Hi Harish,
>>> unfortunately I cannot reproduce the problem over there (gcc 4.2.1/
>>> gfortran 4.5).
>>> Can you try again using another compiler?
>>> Stefan
>>> On May 3, 2010, at 3:26 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>> Hello,
>>>> I am compiling prenek with GNU compilers, gfortran-4.3.2 and
>>>> gcc-4.3.2.
>>>> When I compile it without "BIGMEM" flag it gives an error, the output
>>>> of
>>>> it is attached (error.out). With "BIGMEM" flag turned on, there are no
>>>> compiler errors (compile.out). But when I try to open pretex or prex,
>>>> I
>>>> get the following error.
>>>> [harish at cmtl hole-in-center]$ prex
>>>> Killed
>>>> [harish at cmtl hole-in-center]$ pretex
>>>> Killed
>>>> All the other tools are working fine. Any help in solving this issue
>>>> is
>>>> appreciated.
>>>> Thanks,
>>>> Harish.
>>>> <error.out><compile.out>_______________________________________________
>>>> Nek5000-users mailing list
>>>> Nek5000-users at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
