[Nek5000-users] prex & pretex not working
Mon May 3 08:37:38 CDT 2010
Hi Harish,
unfortunately I cannot reproduce the problem over there (gcc 4.2.1/ gfortran 4.5).
Can you try again using another compiler?
Stefan
On May 3, 2010, at 3:26 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Hello,
> I am compiling prenek with GNU compilers, gfortran-4.3.2 and gcc-4.3.2.
> When I compile it without "BIGMEM" flag it gives an error, the output of
> it is attached (error.out). With "BIGMEM" flag turned on, there are no
> compiler errors (compile.out). But when I try to open pretex or prex, I
> get the following error.
> [harish at cmtl hole-in-center]$ prex
> Killed
> [harish at cmtl hole-in-center]$ pretex
> Killed
> All the other tools are working fine. Any help in solving this issue is
> appreciated.
> Thanks,
> Harish.
> <error.out><compile.out>_______________________________________________
> Nek5000-users mailing list
