[Nek5000-users] map file for conjugate heat
Fri Mar 5 09:29:06 CST 2010
Hi Markus,
I'm still checking into your case --- it doesn't appear to be working
for me (yet)... any luck on your end?
Paul
On Fri, 5 Mar 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Dear Markus,
> I think if you check out the new version of genmap.f and rebuild
> it that it will give a workable .map file for your conjugate heat
> transfer problem.
> Paul
> On Thu, 4 Mar 2010, nek5000-users at lists.mcs.anl.gov wrote:
>> Dear Developers,
>> with the conjugate heat transfer cases, I am running into issues which seem
>> unresolvable. I would thus appreciate your help.
>> Attached is a case with conjugate heat transfer around a circle in 2D
>> (conj.rea). After the map has been generated with genmap (conj.map),
>> running the case results in the messages posted in output. The mesh runs
>> just fine when all elements are defined as fluids (nel=nelv and adding the
>> right boundary conditions in the fluids section), so I don't think it has
>> to do with poor mesh quality.
>> It would be great if you could look into this and see what is wrong and how
>> to fix it.
>> Thanks,
>> Markus
> Nek5000-users mailing list
