[Nek5000-users] map file for conjugate heat
Fri Mar 5 12:57:12 CST 2010
I tried it on 1 and 2, 8 processors, using the newest genmap, and it works!
We'll test a 3D case next and post results.
Thank you very much,
Markus
Quoting nek5000-users at lists.mcs.anl.gov:
> Hi Markus,
> I'm still checking into your case --- it doesn't appear to be working
> for me (yet)... any luck on your end?
> Paul
> On Fri, 5 Mar 2010, nek5000-users at lists.mcs.anl.gov wrote:
> > Dear Markus,
> > I think if you check out the new version of genmap.f and rebuild
> > it that it will give a workable .map file for your conjugate heat
> > transfer problem.
> > Paul
> > On Thu, 4 Mar 2010, nek5000-users at lists.mcs.anl.gov wrote:
> >> Dear Developers,
> >> with the conjugate heat transfer cases, I am running into issues which
> seem
> >> unresolvable. I would thus appreciate your help.
> >> Attached is a case with conjugate heat transfer around a circle in 2D
> >> (conj.rea). After the map has been generated with genmap (conj.map),
> >> running the case results in the messages posted in output. The mesh runs
> >> just fine when all elements are defined as fluids (nel=nelv and adding the
> >> right boundary conditions in the fluids section), so I don't think it has
> >> to do with poor mesh quality.
> >> It would be great if you could look into this and see what is wrong and
> how
> >> to fix it.
> >> Thanks,
> >> Markus
> > _______________________________________________
> > Nek5000-users mailing list
> > Nek5000-users at lists.mcs.anl.gov
> > https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
