[Nek5000-users] map file for conjugate heat
Fri Mar 5 03:39:46 CST 2010
Dear Markus,
I think if you check out the new version of genmap.f and rebuild
it that it will give a workable .map file for your conjugate heat
transfer problem.
Paul
On Thu, 4 Mar 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Dear Developers,
> with the conjugate heat transfer cases, I am running into issues which seem
> unresolvable. I would thus appreciate your help.
> Attached is a case with conjugate heat transfer around a circle in 2D
> (conj.rea). After the map has been generated with genmap (conj.map), running
> the case results in the messages posted in output. The mesh runs just fine
> when all elements are defined as fluids (nel=nelv and adding the right
> boundary conditions in the fluids section), so I don't think it has to do
> with poor mesh quality.
> It would be great if you could look into this and see what is wrong and how
> to fix it.
> Thanks,
> Markus
