[Nek5000-users] genmap
Fri Jun 11 14:16:07 CDT 2010
Hi Stephan,
I just noticed that this thread is still open.  Does the output of my
'ulimit -a' make it clear to you why increasing lelm from 500,000 to
3,000,000 caused genmap to stop working for me?  If so, is it clear a priori
what the maximum lelm on my system could be?
Thanks a lot,
David
On Wed, May 26, 2010 at 1:17 PM, David Goluskin <goluskin at gmail.com> wrote:
> Hi Stephan,
> Here is the output of 'ulimit -a'.  Do you need any other info?  I'm on a
> SiCortex 1458.
> core file size          (blocks, -c) 0
> data seg size           (kbytes, -d) unlimited
> scheduling priority             (-e) 0
> file size               (blocks, -f) unlimited
> pending signals                 (-i) 4089
> max locked memory       (kbytes, -l) 64000
> max memory size         (kbytes, -m) unlimited
> open files                      (-n) 8192
> pipe size            (512 bytes, -p) 8
> POSIX message queues     (bytes, -q) 819200
> real-time priority              (-r) 0
> stack size              (kbytes, -s) 8192
> cpu time               (seconds, -t) unlimited
> max user processes              (-u) 4089
> virtual memory          (kbytes, -v) unlimited
> file locks                      (-x) unlimited
> Thanks,
> David
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100611/62f86e29/attachment.html>
