[Nek5000-users] genmap
Sun Jun 13 06:19:28 CDT 2010
Hi David,
I guess you need to lower the memory footprint of GENMAP because you don't have enough memory available. Try to change the parameter 'lelm' in tools/genmap/SIZE and recompile GENMAP.
Stefan
On May 26, 2010, at 7:17 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Stephan,
> Here is the output of 'ulimit -a'.  Do you need any other info?  I'm on a SiCortex 1458.
> core file size          (blocks, -c) 0
> data seg size           (kbytes, -d) unlimited
> scheduling priority             (-e) 0
> file size               (blocks, -f) unlimited
> pending signals                 (-i) 4089
> max locked memory       (kbytes, -l) 64000
> max memory size         (kbytes, -m) unlimited
> open files                      (-n) 8192
> pipe size            (512 bytes, -p) 8
> POSIX message queues     (bytes, -q) 819200
> real-time priority              (-r) 0
> stack size              (kbytes, -s) 8192
> cpu time               (seconds, -t) unlimited
> max user processes              (-u) 4089
> virtual memory          (kbytes, -v) unlimited
> file locks                      (-x) unlimited
> Thanks,
> David
> Nek5000-users mailing list
