[Nek5000-users] New Recycling BC based on interpolation
Sat Jul 17 21:19:59 CDT 2010
Hi Markus,
I don't know why this wouldn't work for nelgt > nelgv.
I would say we don't know the performance hit yet - I think
someone is looking into this question.  Performance will of
course vary significantly from problem to problem and platform
to platform.   I suspect that it should not be a major hit ---
have you observed otherwise?
Paul
On Sat, 17 Jul 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Aleks,
> thanks for the code, I looked over it and have two questions:
> -at some point, it is mentioned that this method does not work if
> nelgt>nelgv. Why is that? I am asking because this will be applied to a
> conjugate HT problem (although the recycling part is purely concerning
> flow+convection). Will this problem also occur when only findpts is used
> instead of intpts?
> -is there a performance difference between calling intpts as opposed to gs_op
> (as is done in the turbJet example) every time step for large scale
> production runs? The latter is what I used in my version.
> Thanks,
> Markus
>> Hi Michael and Markus,
>> Here is a test case for an unsteady pipe flow with Michael's GambitPipe.rea
>> file which sets inlet Recycling BCs based on interpolation from a
>> cross-section downstream that you specify by a multiple of the inlet
>> normal:
>> http://www.mcs.anl.gov/~obabko/z4.tgz
>> Let me know if you have any questions.
>> Best,
>> Aleks
>> ----- Original Message -----
>> From: nek5000-users at lists.mcs.anl.gov
>> To: nek5000-users at lists.mcs.anl.gov
>> Sent: Thursday, July 8, 2010 5:06:48 PM GMT -06:00 US/Canada Central
>> Subject: Re: [Nek5000-users] New Recycling BC method?
>> No worries, just checkin in to see how it was going, thanks for the update!
>> Look forward to trying it out!
>> - Michael
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
