[Nek5000-users] New Recycling BC based on interpolation
Sat Jul 17 14:57:09 CDT 2010
Hi Aleks,
thanks for the code, I looked over it and have two questions:
-at some point, it is mentioned that this method does not work if
nelgt>nelgv. Why is that? I am asking because this will be applied to a
conjugate HT problem (although the recycling part is purely concerning
flow+convection). Will this problem also occur when only findpts is used
instead of intpts?
-is there a performance difference between calling intpts as opposed to
gs_op (as is done in the turbJet example) every time step for large
scale production runs? The latter is what I used in my version.
Markus
nek5000-users at lists.mcs.anl.gov wrote:
> Hi Michael and Markus,
> Here is a test case for an unsteady pipe flow with Michael's GambitPipe.rea file which sets inlet Recycling BCs based on interpolation from a cross-section downstream that you specify by a multiple of the inlet normal:
> http://www.mcs.anl.gov/~obabko/z4.tgz
> Let me know if you have any questions.
> Best,
> Aleks
> From: nek5000-users at lists.mcs.anl.gov
> To: nek5000-users at lists.mcs.anl.gov
> Sent: Thursday, July 8, 2010 5:06:48 PM GMT -06:00 US/Canada Central
> Subject: Re: [Nek5000-users] New Recycling BC method?
> No worries, just checkin in to see how it was going, thanks for the update! Look forward to trying it out!
> - Michael
> Nek5000-users mailing list
