[Nek5000-users] Nek5000 example errors
Wed Dec 29 15:01:10 CST 2010
John,
Am cc'g this to the users list in case anyone else has seen this
problem w/ gfortran / gcc.
Paul
On Wed, 29 Dec 2010, John Akerley wrote:
> Yes, also using gcc (both version 4.4).  I did switch IFMPI to false.
> Also, I re-downloaded the code yesterday due to other problems, so I
> assume it's the latest version.  I got a similar error when trying the
> turbChannel example.  The compilation is successful, but after trying
> either nek or nekb, I get an error.  Attached is makenek.
> Thanks,
> John
> On Wed, Dec 29, 2010 at 12:30 PM, Paul Fischer <fischer at mcs.anl.gov> wrote:
>> Hi John,
>> Are you also using gcc ?
>> Did you switch IFMPI to false in makenek ?
>> Did you just recently download the code ? (The test
>> that I just made was done by downloading the current
>> code after your previous email.)
>> Confused, but certain we'll get to the bottom of this...
>> Paul
>>> Paul,
>>> I tried this and still received "Right-handed check failed for  256
>>> elements.  Exiting in routine VERRHE" after using grep -i err logfile
>>> | tail command.  I am using the gfortran compiler (no mpi).  The
>>> machine is a 64 bit with Redhat.
>>> On Wed, Dec 29, 2010 at 12:21 PM, Paul Fischer <fischer at mcs.anl.gov>
>>> wrote:
>>>> Hi John,
>>>> I just tried this myself and it worked ok.
>>>> Can you try the following:
>>>> makenek clean
>>>> makenek eddy_uv
>>>> nekb eddy_uv
>>>> (Note, I've posted a new manual online, accessible via the
>>>> wiki or directly via:
>>>> www.mcs.anl.gov/~fischer/new.pdf
>>>> ... and this will be continually updated.)
>>>> The "nekb" script is in nek5_svn/trunk/tools/scripts
>>>> Please let me know if the above works.   Q: what compiler
>>>> are you using ?
>>>> Paul
>>>>> Hi Paul,
>>>>> I have nek5000 installed and running on our linux machine, but I am
>>>>> running into the same error when trying a few of the examples.  The
>>>>> logfile is created, but when checking the error I get "Right-handed
>>>>> check failed for  256 elements.  Exiting in routine VERRHE".  Do you
>>>>> have a solution?  I attached the logfile.
>>>>> Thanks,
>>>>> John Akerley
