[Nek5000-users] Temperature gradient at a point
Thu Aug 26 14:18:39 CDT 2010
Is there any reason why a conjucate heat transfer case should not work with
IFLOMACH turned on?
I did modify the uservp to set utrans = 1./temp.
Pradeep
c-----------------------------------------------------------------------
      subroutine uservp (ix,iy,iz,ieg)
      include 'SIZE'
      include 'TOTAL'
      include 'NEKUSE'
      if (ifield.eq.1) then
         utrans  = 1./temp
c         utrans = param(1)
         udiff   = param(2)
      else
         utrans  = 1./temp        ! thermal properties
c         utrans = param(7)
         udiff   = param(8)
         if (ieg .gt. nelgv) then  ! properties in the solid
            udiff   = 0.1*param(8) ! conductivity
            utrans  = 1.0
         endif
      endif
      return
      end
On Mon, Aug 23, 2010 at 4:40 PM, Pradeep Rao <stringsofdurga at gmail.com>wrote:
> Thanks Aleks,
> Will give that a try.
> On Mon, Aug 23, 2010 at 4:25 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>> Hi Pradeep,
>> Dependence of conductivity on time and space is not a problem once one
>> uses non zero p30 in .rea that activates a call to uservp of .usr file
>> If you also need a dependence of conductivity on temperature you may want
>> to consider either using the values from the previous time step or doing
>> extrapolation in time.
>> Best,
>> Aleks
>> On Mon, 23 Aug 2010, nek5000-users at lists.mcs.anl.gov wrote:
>>  Hi Paul,
>>> Thanks for the detailed reply. The reason I'm not solving it as a
>>> conjugate
>>> heat transfer problem, is that thermal conductivity is a function of
>>> temperature based on some curve fit equations, and I am not sure how to
>>> implement that.
>>> Thanks,
>>> Pradeep
>>> On Mon, Aug 23, 2010 at 4:04 PM, <nek5000-users at lists.mcs.anl.gov>
>>> wrote:
>>>> Hi Pradeep,
>>>> Why not just solve the conjugate heat transfer problem directly
>>>> using fluid + solid elements in nek?
>>>> Also, nek supports full Robin boundary conditions if you wish
>>>> to do a Newton law of cooling:  k*dT/dn . n_hat = h*(T-Tinf), where Tinf
>>>> is
>>>> the external temperature and h is the heat transfer coefficient, both of
>>>> which can be functions of time and space.
>>>> Regarding gradm1, you would call it from userchk, and store
>>>> the output in arrays in a common block, e.g., as below.
>>>> Paul
>>>>     subroutine userchk
>>>>     common /mygrad/ tx(lx1,ly1,lz1,lelt)
>>>>    $              , ty(lx1,ly1,lz1,lelt)
>>>>    $              , tz(lx1,ly1,lz1,lelt)
>>>>     call gradm1(tx,ty,tz,t)
>>>>     subroutine userbc (ix,iy,iz,iside,eg)
>>>>     include 'SIZE'
>>>>     include 'TOTAL'
>>>>     include 'NEKUSE'
>>>>     integer e,eg
>>>>     e = gllel(eg) ! global element number to processor-local el. #
>>>>     gtx=tx(ix,iy,iz,e)
>>>>     gty=ty(ix,iy,iz,e)
>>>>     gtz=tz(ix,iy,iz,e)
>>>>  Hi Paul,
>>>>> I am basically trying to solve a conjugate heat transfer problem in an
>>>>> iterative manner, for flow over an infinitely long cylinder (2D).
>>>>> I need to use the heat transfer at the boundary, to calculate the new
>>>>> temperature at the boundary for the next time step. The
>>>>> temperature for the next time step is solved for using this heat flux,
>>>>> by
>>>>> a
>>>>> function in the usr file using an FEM algorithm for the solid part
>>>>> (cylinder). The bc type I am using is Temperature - fortran function.
>>>>> Regards,
>>>>> Pradeep
>>>>> On Mon, Aug 23, 2010 at 2:50 PM, <nek5000-users at lists.mcs.anl.gov>
>>>>> wrote:
>>>>>  Pradeep,
>>>>>> if you give me some idea of the nature of your bc, I can
>>>>>> perhaps help --- there are a large number of bc types already
>>>>>> supported inside nek
>>>>>> Paul
>>>>>>  Hi,
>>>>>>> I wanted to know if there was a way to find the temperature gradient
>>>>>>> at
>>>>>>> a
>>>>>>> point. I need that information in the userbc function.
>>>>>>> I tried using gradm1(), but I am not sure how to get the value at a
>>>>>>> given
>>>>>>> point.
>>>>>>> Thanks,
>>>>>>> Pradeep
>>>>>>>  _______________________________________________
>>>>>>>  Nek5000-users mailing list
>>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>>>> Pradeep C. Rao
>>>>> Graduate Research Assistant for FT2L (http://www1.mengr.tamu.edu/FT2L/
>>>>> Department of Mechanical Engineering
>>>>> Texas A&M University
>>>>> College Station, TX 77843-3123
>>>>> 428 Engineering Physics Building
>>>>> (713) 210-9769
>>>>>  uuuu
>>>> C
>>>> C  USER SPECIFIED ROUTINES:
>>>> C
>>>> C     - boundary conditions
>>>> C     - initial conditions
>>>> C     - variable properties
>>>> C     - local acceleration for fluid (a)
>>>> C     - forcing function for passive scalar (q)
>>>> C     - general purpose routine for checking errors etc.
>>>> C
>>>>     subroutine uservp (ix,iy,iz,eg)
>>>>     include 'SIZE'
>>>>     include 'TOTAL'
>>>>     include 'NEKUSE'
>>>>     integer e,f,eg
>>>> c     e = gllel(eg)
>>>>     udiff =0.
>>>>     utrans=0.
>>>>     return
>>>>     end
>>>>     subroutine userf  (ix,iy,iz,eg)
>>>>     include 'SIZE'
>>>>     include 'TOTAL'
>>>>     include 'NEKUSE'
>>>>     integer e,f,eg
>>>> c     e = gllel(eg)
>>>> c     Note: this is an acceleration term, NOT a force!
>>>> c     Thus, ffx will subsequently be multiplied by rho(x,t).
>>>>     ffx = 0.0
>>>>     ffy = 0.0
>>>>     ffz = 0.0
>>>>     return
>>>>     end
>>>>     subroutine userq  (ix,iy,iz,eg)
>>>>     include 'SIZE'
>>>>     include 'TOTAL'
>>>>     include 'NEKUSE'
>>>>     integer e,f,eg
>>>> c     e = gllel(eg)
>>>>     qvol   = 0.0
>>>>     return
>>>>     end
>>>>     subroutine userchk
>>>>     include 'SIZE'
>>>>     include 'TOTAL'
>>>>     return
>>>>     end
>>>>     subroutine userbc (ix,iy,iz,iside,ieg)
>>>>     include 'SIZE'
>>>>     include 'TOTAL'
>>>>     include 'NEKUSE'
>>>>     ux=0.0
>>>>     uy=0.0
>>>>     uz=0.0
>>>>     temp=0.0
>>>>     return
>>>>     end
>>>>     subroutine useric (ix,iy,iz,ieg)
>>>>     include 'SIZE'
>>>>     include 'TOTAL'
>>>>     include 'NEKUSE'
>>>>     ux=0.0
>>>>     uy=0.0
>>>>     uz=0.0
>>>>     temp=0
>>>>     return
>>>>     end
>>>>     subroutine usrdat
>>>>     include 'SIZE'
>>>>     include 'TOTAL'
>>>> c
>>>>     return
>>>>     end
>>>>     subroutine usrdat2
>>>>     include 'SIZE'
>>>>     include 'TOTAL'
>>>>     param(66) = 4.   ! These give the std nek binary i/o and are
>>>>     param(67) = 4.   ! good default values
>>>>     return
>>>>     end
>>>>     subroutine usrdat3
>>>>     include 'SIZE'
>>>>     include 'TOTAL'
>>>> c
>>>>     return
>>>>     end
>>> Pradeep C. Rao
>>> Graduate Research Assistant for FT2L (http://www1.mengr.tamu.edu/FT2L/)
>>> (713) 210-9769
> Pradeep C. Rao
> (713) 210-9769
Pradeep C. Rao
(713) 210-9769
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100826/96aef715/attachment.html>
