[Nek5000-users] Temperature gradient at a point
Mon Aug 23 16:40:04 CDT 2010
Thanks Aleks,
Will give that a try.
On Mon, Aug 23, 2010 at 4:25 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Pradeep,
> Dependence of conductivity on time and space is not a problem once one uses
> non zero p30 in .rea that activates a call to uservp of .usr file
> If you also need a dependence of conductivity on temperature you may want
> to consider either using the values from the previous time step or doing
> extrapolation in time.
> Best,
> Aleks
> On Mon, 23 Aug 2010, nek5000-users at lists.mcs.anl.gov wrote:
>  Hi Paul,
>> Thanks for the detailed reply. The reason I'm not solving it as a
>> conjugate
>> heat transfer problem, is that thermal conductivity is a function of
>> temperature based on some curve fit equations, and I am not sure how to
>> implement that.
>> Thanks,
>> Pradeep
>> On Mon, Aug 23, 2010 at 4:04 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>>> Hi Pradeep,
>>> Why not just solve the conjugate heat transfer problem directly
>>> using fluid + solid elements in nek?
>>> Also, nek supports full Robin boundary conditions if you wish
>>> to do a Newton law of cooling:  k*dT/dn . n_hat = h*(T-Tinf), where Tinf
>>> is
>>> the external temperature and h is the heat transfer coefficient, both of
>>> which can be functions of time and space.
>>> Regarding gradm1, you would call it from userchk, and store
>>> the output in arrays in a common block, e.g., as below.
>>> Paul
>>>     subroutine userchk
>>>     common /mygrad/ tx(lx1,ly1,lz1,lelt)
>>>    $              , ty(lx1,ly1,lz1,lelt)
>>>    $              , tz(lx1,ly1,lz1,lelt)
>>>     call gradm1(tx,ty,tz,t)
>>>     subroutine userbc (ix,iy,iz,iside,eg)
>>>     include 'SIZE'
>>>     include 'TOTAL'
>>>     include 'NEKUSE'
>>>     integer e,eg
>>>     e = gllel(eg) ! global element number to processor-local el. #
>>>     gtx=tx(ix,iy,iz,e)
>>>     gty=ty(ix,iy,iz,e)
>>>     gtz=tz(ix,iy,iz,e)
>>>  Hi Paul,
>>>> I am basically trying to solve a conjugate heat transfer problem in an
>>>> iterative manner, for flow over an infinitely long cylinder (2D).
>>>> I need to use the heat transfer at the boundary, to calculate the new
>>>> temperature at the boundary for the next time step. The
>>>> temperature for the next time step is solved for using this heat flux,
>>>> by
>>>> a
>>>> function in the usr file using an FEM algorithm for the solid part
>>>> (cylinder). The bc type I am using is Temperature - fortran function.
>>>> Regards,
>>>> Pradeep
>>>> On Mon, Aug 23, 2010 at 2:50 PM, <nek5000-users at lists.mcs.anl.gov>
>>>> wrote:
>>>>  Pradeep,
>>>>> if you give me some idea of the nature of your bc, I can
>>>>> perhaps help --- there are a large number of bc types already
>>>>> supported inside nek
>>>>> Paul
>>>>>  Hi,
>>>>>> I wanted to know if there was a way to find the temperature gradient
>>>>>> at
>>>>>> a
>>>>>> point. I need that information in the userbc function.
>>>>>> I tried using gradm1(), but I am not sure how to get the value at a
>>>>>> given
>>>>>> point.
>>>>>> Thanks,
>>>>>> Pradeep
>>>>>>  _______________________________________________
>>>>>>  Nek5000-users mailing list
>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>>> Pradeep C. Rao
>>>> Graduate Research Assistant for FT2L (http://www1.mengr.tamu.edu/FT2L/)
>>>> Department of Mechanical Engineering
>>>> Texas A&M University
>>>> College Station, TX 77843-3123
>>>> 428 Engineering Physics Building
>>>> (713) 210-9769
>>>>  uuuu
>>> c-----------------------------------------------------------------------
>>> C
>>> C  USER SPECIFIED ROUTINES:
>>> C
>>> C     - boundary conditions
>>> C     - initial conditions
>>> C     - variable properties
>>> C     - local acceleration for fluid (a)
>>> C     - forcing function for passive scalar (q)
>>> C     - general purpose routine for checking errors etc.
>>> C
>>>     subroutine uservp (ix,iy,iz,eg)
>>>     include 'SIZE'
>>>     include 'TOTAL'
>>>     include 'NEKUSE'
>>>     integer e,f,eg
>>> c     e = gllel(eg)
>>>     udiff =0.
>>>     utrans=0.
>>>     return
>>>     end
>>>     subroutine userf  (ix,iy,iz,eg)
>>>     include 'SIZE'
>>>     include 'TOTAL'
>>>     include 'NEKUSE'
>>>     integer e,f,eg
>>> c     e = gllel(eg)
>>> c     Note: this is an acceleration term, NOT a force!
>>> c     Thus, ffx will subsequently be multiplied by rho(x,t).
>>>     ffx = 0.0
>>>     ffy = 0.0
>>>     ffz = 0.0
>>>     return
>>>     end
>>>     subroutine userq  (ix,iy,iz,eg)
>>>     include 'SIZE'
>>>     include 'TOTAL'
>>>     include 'NEKUSE'
>>>     integer e,f,eg
>>> c     e = gllel(eg)
>>>     qvol   = 0.0
>>>     return
>>>     end
>>>     subroutine userchk
>>>     include 'SIZE'
>>>     include 'TOTAL'
>>>     return
>>>     end
>>>     subroutine userbc (ix,iy,iz,iside,ieg)
>>>     include 'SIZE'
>>>     include 'TOTAL'
>>>     include 'NEKUSE'
>>>     ux=0.0
>>>     uy=0.0
>>>     uz=0.0
>>>     temp=0.0
>>>     return
>>>     end
>>>     subroutine useric (ix,iy,iz,ieg)
>>>     include 'SIZE'
>>>     include 'TOTAL'
>>>     include 'NEKUSE'
>>>     ux=0.0
>>>     uy=0.0
>>>     uz=0.0
>>>     temp=0
>>>     return
>>>     end
>>>     subroutine usrdat
>>>     include 'SIZE'
>>>     include 'TOTAL'
>>> c
>>>     return
>>>     end
>>>     subroutine usrdat2
>>>     include 'SIZE'
>>>     include 'TOTAL'
>>>     param(66) = 4.   ! These give the std nek binary i/o and are
>>>     param(67) = 4.   ! good default values
>>>     return
>>>     end
>>>     subroutine usrdat3
>>>     include 'SIZE'
>>>     include 'TOTAL'
>>> c
>>>     return
>>>     end
>> Pradeep C. Rao
>> (713) 210-9769
Pradeep C. Rao
(713) 210-9769
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100823/595ba6c8/attachment.html>
