[Nek5000-users] Temperature gradient at a point
Thu Aug 26 15:50:08 CDT 2010
This combination should work!
Stefan
On Thu, Aug 26, 2010 at 9:18 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi,
> Is there any reason why a conjucate heat transfer case should not work with
> IFLOMACH turned on?
> I did modify the uservp to set utrans = 1./temp.
> Thanks,
> Pradeep
> c-----------------------------------------------------------------------
>       subroutine uservp (ix,iy,iz,ieg)
>       include 'SIZE'
>       include 'TOTAL'
>       include 'NEKUSE'
>       if (ifield.eq.1) then
>          utrans  = 1./temp
> c         utrans = param(1)
>          udiff   = param(2)
>       else
>          utrans  = 1./temp        ! thermal properties
> c         utrans = param(7)
>          udiff   = param(8)
>          if (ieg .gt. nelgv) then  ! properties in the solid
>             udiff   = 0.1*param(8) ! conductivity
>             utrans  = 1.0
>          endif
>       endif
>       return
>       end
> On Mon, Aug 23, 2010 at 4:40 PM, Pradeep Rao <stringsofdurga at gmail.com>wrote:
>> Thanks Aleks,
>> Will give that a try.
>> On Mon, Aug 23, 2010 at 4:25 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
>>> Hi Pradeep,
>>> Dependence of conductivity on time and space is not a problem once one
>>> uses non zero p30 in .rea that activates a call to uservp of .usr file
>>> If you also need a dependence of conductivity on temperature you may want
>>> to consider either using the values from the previous time step or doing
>>> extrapolation in time.
>>> Best,
>>> Aleks
>>> On Mon, 23 Aug 2010, nek5000-users at lists.mcs.anl.gov wrote:
>>>  Hi Paul,
>>>> Thanks for the detailed reply. The reason I'm not solving it as a
>>>> conjugate
>>>> heat transfer problem, is that thermal conductivity is a function of
>>>> temperature based on some curve fit equations, and I am not sure how to
>>>> implement that.
>>>> Thanks,
>>>> Pradeep
>>>> On Mon, Aug 23, 2010 at 4:04 PM, <nek5000-users at lists.mcs.anl.gov>
>>>> wrote:
>>>>> Hi Pradeep,
>>>>> Why not just solve the conjugate heat transfer problem directly
>>>>> using fluid + solid elements in nek?
>>>>> Also, nek supports full Robin boundary conditions if you wish
>>>>> to do a Newton law of cooling:  k*dT/dn . n_hat = h*(T-Tinf), where
>>>>> Tinf is
>>>>> the external temperature and h is the heat transfer coefficient, both
>>>>> of
>>>>> which can be functions of time and space.
>>>>> Regarding gradm1, you would call it from userchk, and store
>>>>> the output in arrays in a common block, e.g., as below.
>>>>> Paul
>>>>>     subroutine userchk
>>>>>     common /mygrad/ tx(lx1,ly1,lz1,lelt)
>>>>>    $              , ty(lx1,ly1,lz1,lelt)
>>>>>    $              , tz(lx1,ly1,lz1,lelt)
>>>>>     call gradm1(tx,ty,tz,t)
>>>>>     subroutine userbc (ix,iy,iz,iside,eg)
>>>>>     include 'SIZE'
>>>>>     include 'TOTAL'
>>>>>     include 'NEKUSE'
>>>>>     integer e,eg
>>>>>     e = gllel(eg) ! global element number to processor-local el. #
>>>>>     gtx=tx(ix,iy,iz,e)
>>>>>     gty=ty(ix,iy,iz,e)
>>>>>     gtz=tz(ix,iy,iz,e)
>>>>>  Hi Paul,
>>>>>> I am basically trying to solve a conjugate heat transfer problem in an
>>>>>> iterative manner, for flow over an infinitely long cylinder (2D).
>>>>>> I need to use the heat transfer at the boundary, to calculate the new
>>>>>> temperature at the boundary for the next time step. The
>>>>>> temperature for the next time step is solved for using this heat flux,
>>>>>> by
>>>>>> a
>>>>>> function in the usr file using an FEM algorithm for the solid part
>>>>>> (cylinder). The bc type I am using is Temperature - fortran function.
>>>>>> Regards,
>>>>>> Pradeep
>>>>>> On Mon, Aug 23, 2010 at 2:50 PM, <nek5000-users at lists.mcs.anl.gov>
>>>>>> wrote:
>>>>>>  Pradeep,
>>>>>>> if you give me some idea of the nature of your bc, I can
>>>>>>> perhaps help --- there are a large number of bc types already
>>>>>>> supported inside nek
>>>>>>> Paul
>>>>>>>  Hi,
>>>>>>>> I wanted to know if there was a way to find the temperature gradient
>>>>>>>> at
>>>>>>>> a
>>>>>>>> point. I need that information in the userbc function.
>>>>>>>> I tried using gradm1(), but I am not sure how to get the value at a
>>>>>>>> given
>>>>>>>> point.
>>>>>>>> Thanks,
>>>>>>>> Pradeep
>>>>>>>>  _______________________________________________
>>>>>>>>  Nek5000-users mailing list
>>>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>>>>> Pradeep C. Rao
>>>>>> Graduate Research Assistant for FT2L (
>>>>>> http://www1.mengr.tamu.edu/FT2L/)
>>>>>> Department of Mechanical Engineering
>>>>>> Texas A&M University
>>>>>> College Station, TX 77843-3123
>>>>>> 428 Engineering Physics Building
>>>>>> (713) 210-9769
>>>>>>  uuuu
>>>>> C
>>>>> C  USER SPECIFIED ROUTINES:
>>>>> C
>>>>> C     - boundary conditions
>>>>> C     - initial conditions
>>>>> C     - variable properties
>>>>> C     - local acceleration for fluid (a)
>>>>> C     - forcing function for passive scalar (q)
>>>>> C     - general purpose routine for checking errors etc.
>>>>> C
>>>>>     subroutine uservp (ix,iy,iz,eg)
>>>>>     include 'SIZE'
>>>>>     include 'TOTAL'
>>>>>     include 'NEKUSE'
>>>>>     integer e,f,eg
>>>>> c     e = gllel(eg)
>>>>>     udiff =0.
>>>>>     utrans=0.
>>>>>     return
>>>>>     end
>>>>>     subroutine userf  (ix,iy,iz,eg)
>>>>>     include 'SIZE'
>>>>>     include 'TOTAL'
>>>>>     include 'NEKUSE'
>>>>>     integer e,f,eg
>>>>> c     e = gllel(eg)
>>>>> c     Note: this is an acceleration term, NOT a force!
>>>>> c     Thus, ffx will subsequently be multiplied by rho(x,t).
>>>>>     ffx = 0.0
>>>>>     ffy = 0.0
>>>>>     ffz = 0.0
>>>>>     return
>>>>>     end
>>>>>     subroutine userq  (ix,iy,iz,eg)
>>>>>     include 'SIZE'
>>>>>     include 'TOTAL'
>>>>>     include 'NEKUSE'
>>>>>     integer e,f,eg
>>>>> c     e = gllel(eg)
>>>>>     qvol   = 0.0
>>>>>     return
>>>>>     end
>>>>>     subroutine userchk
>>>>>     include 'SIZE'
>>>>>     include 'TOTAL'
>>>>>     return
>>>>>     end
>>>>>     subroutine userbc (ix,iy,iz,iside,ieg)
>>>>>     include 'SIZE'
>>>>>     include 'TOTAL'
>>>>>     include 'NEKUSE'
>>>>>     ux=0.0
>>>>>     uy=0.0
>>>>>     uz=0.0
>>>>>     temp=0.0
>>>>>     return
>>>>>     end
>>>>>     subroutine useric (ix,iy,iz,ieg)
>>>>>     include 'SIZE'
>>>>>     include 'TOTAL'
>>>>>     include 'NEKUSE'
>>>>>     ux=0.0
>>>>>     uy=0.0
>>>>>     uz=0.0
>>>>>     temp=0
>>>>>     return
>>>>>     end
>>>>>     subroutine usrdat
>>>>>     include 'SIZE'
>>>>>     include 'TOTAL'
>>>>> c
>>>>>     return
>>>>>     end
>>>>>     subroutine usrdat2
>>>>>     include 'SIZE'
>>>>>     include 'TOTAL'
>>>>>     param(66) = 4.   ! These give the std nek binary i/o and are
>>>>>     param(67) = 4.   ! good default values
>>>>>     return
>>>>>     end
>>>>>     subroutine usrdat3
>>>>>     include 'SIZE'
>>>>>     include 'TOTAL'
>>>>> c
>>>>>     return
>>>>>     end
>>>> Pradeep C. Rao
>>>> Graduate Research Assistant for FT2L (http://www1.mengr.tamu.edu/FT2L/)
>>>> (713) 210-9769
>> Pradeep C. Rao
>> (713) 210-9769
> Pradeep C. Rao
> (713) 210-9769
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100826/7b028cdf/attachment.html>
