[Nek5000-users] postpro.f compiler problems
Mon Aug 23 15:21:50 CDT 2010
Here is the SIZE file.
Elizabeth
nek5000-users at lists.mcs.anl.gov wrote:
> Hi,
> please post your SIZE file.
> Stefan
> On Mon, Aug 23, 2010 at 8:17 PM, <nek5000-users at lists.mcs.anl.gov
> <mailto:nek5000-users at lists.mcs.anl.gov>> wrote:
>     Hi,
>     I tried to update to the newest version of the code, but I am having
>     trouble getting it to compile. It is having a problem with compiling
>     postpro.f.  It looks like the compiler fails at line 1364 when
>     parameter
>     is used to set a variable equal to a non-constant quantity instead
>     of a
>     constant one.  It looks like this was added in version 537 by
>     Stefan. I've included the end of the output from the compiler,
>     which is the Portland group compiler on Franklin.   At Aleks'
>     suggestion I tried deleting the subroutine g2gi, but that did not
>     fix the problem. I was finally able to get it to compile by using
>     postpro.f from version 536 and deleting the subroutine hpts.
>     That subroutine was causing a similar problem. Elizabeth
>     PGF90-S-0050-Assumed size array, rst, is not a dummy argument
>     (/global/homes/e/ehicks/nek5_svn/trunk/nek/postpro.f: 448)
>     PGF90-S-0050-Assumed size array, dist, is not a dummy argument
>     PGF90-S-0050-Assumed size array, rcode, is not a dummy argument
>     (/global/homes/e/ehicks/nek5_svn/trunk/nek/postpro.f: 449)
>     PGF90-S-0050-Assumed size array, elid, is not a dummy argument
>     PGF90-S-0050-Assumed size array, proc, is not a dummy argument
>     0 inform,   0 warnings,   5 severes, 0 fatal for intpts
>     /opt/cray/xt-asyncpe/3.7/bin/ftn: INFO: linux target is being used
>     ftn -c  -O2 -r8 -Mpreprocess -DMPI -DLONGINT8 -DUNDERSCORE
>     -DGLOBAL_LONG_LONG -I/scratch/scratchdirs/ehicks/nek/runs/run325
>     -I/global/homes/e/ehicks/nek5_svn/trunk/nek -I./
>     /global/homes/e/ehicks/nek5_svn/trunk/nek/qthermal.f -o obj/qthermal.o
>     PGF90-S-0087-Non-constant expression where constant expression
>     required (/global/homes/e/ehicks/nek5_svn/trunk/nek/postpro.f
>     : 1346)
>     0 inform,   0 warnings,   1 severes, 0 fatal for g2gi
>     make: *** [obj/postpro.o] Error 2
>     _______________________________________________
>     Nek5000-users mailing list
>     Nek5000-users at lists.mcs.anl.gov
>     <mailto:Nek5000-users at lists.mcs.anl.gov>
>     https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100823/5d6a0abc/attachment.ksh>
