[Nek5000-users] postpro.f compiler problems
Mon Aug 23 15:47:47 CDT 2010
Your compiler problem seems to be related to the fact that the lpart
parameter is commented. Did you comment this parameter?
c automatically added by makenek
c      parameter(lpart = 10000  ) ! max number of particles
Stefan
On Mon, Aug 23, 2010 at 10:21 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Here is the SIZE file.
> Elizabeth
> nek5000-users at lists.mcs.anl.gov wrote:
>> Hi,
>> please post your SIZE file.
>> Stefan
>> On Mon, Aug 23, 2010 at 8:17 PM, <nek5000-users at lists.mcs.anl.gov<mailto:
>> nek5000-users at lists.mcs.anl.gov>> wrote:
>>    Hi,
>>    I tried to update to the newest version of the code, but I am having
>>    trouble getting it to compile. It is having a problem with compiling
>>    postpro.f.  It looks like the compiler fails at line 1364 when
>>    parameter
>>    is used to set a variable equal to a non-constant quantity instead
>>    of a
>>    constant one.  It looks like this was added in version 537 by
>>    Stefan. I've included the end of the output from the compiler,
>>    which is the Portland group compiler on Franklin.   At Aleks'
>>    suggestion I tried deleting the subroutine g2gi, but that did not
>>    fix the problem. I was finally able to get it to compile by using
>>    postpro.f from version 536 and deleting the subroutine hpts.      That
>> subroutine was causing a similar problem. Elizabeth
>>    PGF90-S-0050-Assumed size array, rst, is not a dummy argument
>>    (/global/homes/e/ehicks/nek5_svn/trunk/nek/postpro.f: 448)
>>    PGF90-S-0050-Assumed size array, dist, is not a dummy argument
>>    PGF90-S-0050-Assumed size array, rcode, is not a dummy argument
>>    (/global/homes/e/ehicks/nek5_svn/trunk/nek/postpro.f: 449)
>>    PGF90-S-0050-Assumed size array, elid, is not a dummy argument
>>    PGF90-S-0050-Assumed size array, proc, is not a dummy argument
>>    0 inform,   0 warnings,   5 severes, 0 fatal for intpts
>>    /opt/cray/xt-asyncpe/3.7/bin/ftn: INFO: linux target is being used
>>    ftn -c  -O2 -r8 -Mpreprocess -DMPI -DLONGINT8 -DUNDERSCORE
>>    -DGLOBAL_LONG_LONG -I/scratch/scratchdirs/ehicks/nek/runs/run325
>>    -I/global/homes/e/ehicks/nek5_svn/trunk/nek -I./
>>    /global/homes/e/ehicks/nek5_svn/trunk/nek/qthermal.f -o obj/qthermal.o
>>    PGF90-S-0087-Non-constant expression where constant expression
>>    required (/global/homes/e/ehicks/nek5_svn/trunk/nek/postpro.f
>>    : 1346)
>>    0 inform,   0 warnings,   1 severes, 0 fatal for g2gi
>>    make: *** [obj/postpro.o] Error 2
>>    _______________________________________________
>>    Nek5000-users mailing list
>>    Nek5000-users at lists.mcs.anl.gov
>>    <mailto:Nek5000-users at lists.mcs.anl.gov>
>>    https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> C     Dimension file to be included
> C
> C     HCUBE array dimensions
> C
>      parameter (ldim=2)
>      parameter (lx1=16,ly1=lx1,lz1=1,lelt=36,lelv=lelt)
>      parameter (lxd=24,lyd=lxd,lzd=1)
>      parameter (lelx=1,lely=1,lelz=1)
> c
>      parameter (lzl=3 + 2*(ldim-3))
> c
>      parameter (lx2=lx1-2)
>      parameter (ly2=ly1-2)
>      parameter (lz2=1)
>      parameter (lx3=lx2)
>      parameter (ly3=ly2)
>      parameter (lz3=lz2)
> c
> c     parameter (lpelv=lelv,lpelt=lelt,lpert=3)  ! perturbation
> c     parameter (lpx1=lx1,lpy1=ly1,lpz1=lz1)     ! array sizes
> c     parameter (lpx2=lx2,lpy2=ly2,lpz2=lz2)
> c
>      parameter (lpelv=1,lpelt=1,lpert=1)        ! perturbation
>      parameter (lpx1=1,lpy1=1,lpz1=1)           ! array sizes
>      parameter (lpx2=1,lpy2=1,lpz2=1)
> c
> c
> c     parameter (lbelv=lelv,lbelt=lelt)          ! MHD
> c     parameter (lbx1=lx1,lby1=ly1,lbz1=lz1)     ! array sizes
> c     parameter (lbx2=lx2,lby2=ly2,lbz2=lz2)
> c
>      parameter (lbelv=1,lbelt=1)                ! MHD
>      parameter (lbx1=1,lby1=1,lbz1=1)           ! array sizes
>      parameter (lbx2=1,lby2=1,lbz2=1)
> c
> C LX1M=LX1 when there are moving meshes; =1 otherwise
>      parameter (lx1m=1,ly1m=1,lz1m=1)
>      parameter (ldimt= 1)                       ! 3 passive scalars + T
>      parameter (ldimt1=ldimt+1)
>      parameter (ldimt3=ldimt+3)
>      parameter (lp   = 1024)
>      parameter (lelg = 1152)
> c
> c     Note:  In the new code, LELGEC should be about sqrt(LELG)
> c
>      PARAMETER (LELGEC = 1)
>      PARAMETER (LXYZ2  = 1)
>      PARAMETER (LXZ21  = 1)
> c
>      PARAMETER (LMAXV=LX1*LY1*LZ1*LELV)
>      PARAMETER (LMAXT=LX1*LY1*LZ1*LELT)
>      PARAMETER (LMAXP=LX2*LY2*LZ2*LELV)
>      PARAMETER (LXZ=LX1*LZ1)
>      PARAMETER (LORDER=3)
>      PARAMETER (MAXOBJ=1,MAXMBR=LELT*6,lhis=10)
> C
> C     Common Block Dimensions
> C
>      PARAMETER (LCTMP0 =2*LX1*LY1*LZ1*LELT)
>      PARAMETER (LCTMP1 =4*LX1*LY1*LZ1*LELT)
> C
> C     The parameter LVEC controls whether an additional 42 field arrays
> C     are required for Steady State Solutions.  If you are not using
> C     Steady State, it is recommended that LVEC=1.
> C
>      PARAMETER (LVEC=1)
> C
> C     Uzawa projection array dimensions
> C
>      parameter (mxprev = 20)
>      parameter (lgmres = 30)
> C
> C     Split projection array dimensions
> C
>      parameter(lmvec = 1)
>      parameter(lsvec = 1)
>      parameter(lstore=lmvec*lsvec)
> c
> c     NONCONFORMING STUFF
> c
>      parameter (maxmor = lelt)
> C
> C     Array dimensions
> C
>      COMMON/DIMN/NELV,NELT,NX1,NY1,NZ1,NX2,NY2,NZ2
>     $,NX3,NY3,NZ3,NDIM,NFIELD,NPERT,NID
>     $,NXD,NYD,NZD
>      parameter(lxo   = lx1) ! max output grid size (lxo>=lx1)
>      integer ax1,ay1,az1,ax2,ay2,az2
>      parameter (ax1=lx1,ay1=ly1,az1=lz1,ax2=lx2,ay2=ly2,az2=lz2) ! running
> averages
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100823/eda5815f/attachment.html>
