[Nek5000-users] postpro.f compiler problems
Mon Aug 23 14:59:41 CDT 2010
please post your SIZE file.
Stefan
On Mon, Aug 23, 2010 at 8:17 PM, <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi,
> I tried to update to the newest version of the code, but I am having
> trouble getting it to compile. It is having a problem with compiling
> postpro.f.  It looks like the compiler fails at line 1364 when parameter
> is used to set a variable equal to a non-constant quantity instead of a
> constant one.  It looks like this was added in version 537 by Stefan. I've
> included the end of the output from the compiler, which is the Portland
> group compiler on Franklin.   At Aleks' suggestion I tried deleting the
> subroutine g2gi, but that did not fix the problem. I was finally able to get
> it to compile by using postpro.f from version 536 and deleting the
> subroutine hpts.   That subroutine was causing a similar problem. Elizabeth
> PGF90-S-0050-Assumed size array, rst, is not a dummy argument
> (/global/homes/e/ehicks/nek5_svn/trunk/nek/postpro.f: 448)
> PGF90-S-0050-Assumed size array, dist, is not a dummy argument
> PGF90-S-0050-Assumed size array, rcode, is not a dummy argument
> (/global/homes/e/ehicks/nek5_svn/trunk/nek/postpro.f: 449)
> PGF90-S-0050-Assumed size array, elid, is not a dummy argument
> PGF90-S-0050-Assumed size array, proc, is not a dummy argument
> 0 inform,   0 warnings,   5 severes, 0 fatal for intpts
> /opt/cray/xt-asyncpe/3.7/bin/ftn: INFO: linux target is being used
> ftn -c  -O2 -r8 -Mpreprocess -DMPI -DLONGINT8 -DUNDERSCORE
> -DGLOBAL_LONG_LONG -I/scratch/scratchdirs/ehicks/nek/runs/run325
> -I/global/homes/e/ehicks/nek5_svn/trunk/nek -I./
> /global/homes/e/ehicks/nek5_svn/trunk/nek/qthermal.f -o obj/qthermal.o
> PGF90-S-0087-Non-constant expression where constant expression required
> : 1346)
> 0 inform,   0 warnings,   1 severes, 0 fatal for g2gi
> make: *** [obj/postpro.o] Error 2
> Nek5000-users mailing list
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100823/c6689f9b/attachment.html>
