[Nek5000-users] Nekmerge question
Thu Apr 22 07:43:30 CDT 2010
Thanks a lot for those tips.
I assume that prex and prenek are the same, right ?
In that case, I have some trouble when compiling prenek:
mxm.f(54): (col. 13) remark: LOOP WAS VECTORIZED.
gcc -c -DUNDERSCORE -Dr8 xdriver.c
xdriver.c: In function ‘TypeChar’:
xdriver.c:759: attention : comparaison est toujours vraie en raison
d'une gamme limitée de type de données
ifort -o /home/loiseau/BricoNek/cylindre/prex prenek.o curve.o edit.o
build.o build1.o build2.o bound.o plot.o xinterface.o glomod.o legend.o
vprops.o iolib.o subs.o zipper2.o postnek6.o screen.o revert.o crs.o
mxm.o xdriver.o -L/usr/X11R6/lib -lX11 -lm
prenek.o: In function `intcnd_':
prenek.f:(.text+0x408): relocation truncated to fit: R_X86_64_PC32
against symbol `ibasic_' defined in COMMON section in prenek.o
prenek.f:(.text+0x410): relocation truncated to fit: R_X86_64_PC32
prenek.o: In function `readln_':
prenek.f:(.text+0x6c2): relocation truncated to fit: R_X86_64_PC32
against symbol `modes_' defined in COMMON section in prenek.o
prenek.f:(.text+0x6fd): relocation truncated to fit: R_X86_64_32S
against symbol `chaar_' defined in COMMON section in prenek.o
prenek.f:(.text+0x759): relocation truncated to fit: R_X86_64_32S
prenek.f:(.text+0x76b): relocation truncated to fit: R_X86_64_32S
prenek.f:(.text+0x79e): relocation truncated to fit: R_X86_64_32S
prenek.o: In function `drivef_':
prenek.f:(.text+0x81d): relocation truncated to fit: R_X86_64_PC32
against symbol `fortrn_' defined in COMMON section in prenek.o
prenek.f:(.text+0x838): relocation truncated to fit: R_X86_64_PC32
against symbol `logi_' defined in COMMON section in prenek.o
prenek.f:(.text+0x8f6): relocation truncated to fit: R_X86_64_PC32
prenek.f:(.text+0x931): additional relocation overflows omitted from the
output
make[1]: *** [prex] Erreur 1
make[1]: quittant le répertoire «
/home/loiseau/nek5_svn/trunk/tools/prenek »
make: *** [all] Erreur 1
Jean-Christophe
