[Nek5000-users] Nekmerge question
Thu Apr 22 07:53:57 CDT 2010
Please enable the big memory support in maketools (BIGMEM="true") and try again.
Stefan
On Apr 22, 2010, at 2:43 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Thanks a lot for those tips.
> I assume that prex and prenek are the same, right ?
> In that case, I have some trouble when compiling prenek:
> mxm.f(54): (col. 13) remark: LOOP WAS VECTORIZED.
> gcc -c -DUNDERSCORE -Dr8 xdriver.c
> xdriver.c: In function ‘TypeChar’:
> xdriver.c:759: attention : comparaison est toujours vraie en raison d'une gamme limitée de type de données
> ifort -o /home/loiseau/BricoNek/cylindre/prex prenek.o curve.o edit.o build.o build1.o build2.o bound.o plot.o xinterface.o glomod.o legend.o vprops.o iolib.o subs.o zipper2.o postnek6.o screen.o revert.o crs.o mxm.o xdriver.o -L/usr/X11R6/lib -lX11 -lm
> prenek.o: In function `intcnd_':
> prenek.f:(.text+0x408): relocation truncated to fit: R_X86_64_PC32 against symbol `ibasic_' defined in COMMON section in prenek.o
> prenek.f:(.text+0x410): relocation truncated to fit: R_X86_64_PC32 against symbol `ibasic_' defined in COMMON section in prenek.o
> prenek.o: In function `readln_':
> prenek.f:(.text+0x6c2): relocation truncated to fit: R_X86_64_PC32 against symbol `modes_' defined in COMMON section in prenek.o
> prenek.f:(.text+0x6fd): relocation truncated to fit: R_X86_64_32S against symbol `chaar_' defined in COMMON section in prenek.o
> prenek.f:(.text+0x759): relocation truncated to fit: R_X86_64_32S against symbol `chaar_' defined in COMMON section in prenek.o
> prenek.f:(.text+0x76b): relocation truncated to fit: R_X86_64_32S against symbol `chaar_' defined in COMMON section in prenek.o
> prenek.f:(.text+0x79e): relocation truncated to fit: R_X86_64_32S against symbol `chaar_' defined in COMMON section in prenek.o
> prenek.o: In function `drivef_':
> prenek.f:(.text+0x81d): relocation truncated to fit: R_X86_64_PC32 against symbol `fortrn_' defined in COMMON section in prenek.o
> prenek.f:(.text+0x838): relocation truncated to fit: R_X86_64_PC32 against symbol `logi_' defined in COMMON section in prenek.o
> prenek.f:(.text+0x8f6): relocation truncated to fit: R_X86_64_PC32 against symbol `modes_' defined in COMMON section in prenek.o
> prenek.f:(.text+0x931): additional relocation overflows omitted from the output
> make[1]: *** [prex] Erreur 1
> make[1]: quittant le répertoire « /home/loiseau/nek5_svn/trunk/tools/prenek »
> make: *** [all] Erreur 1
> Jean-Christophe
> Nek5000-users mailing list
