[Nek5000-users] Periodic flow around sphere
Thu Apr 22 07:02:25 CDT 2010
Fred,
Your other email was too large to make it onto the list.
It appears that the issue is the following -- automatic
timestep selection (i.e., dt > or = 0), doesn't appear to
work with the projection acceleration (param 93, 94, 95 > 0).
So either set param 12 < 0, such that dt = | param 12 |, or
set p93-95 == 0.
I'm pretty certain that will take care of the problem.
(I almost invariably run with dt < 0...)
Paul
On Thu, 22 Apr 2010, nek5000-users at lists.mcs.anl.gov wrote:
> To be more precise - by nested,  I really meant that there are
> elements that overlap the same regions...  this would be very
> confusing to genmap/nek --- it's one of the cases for which we
> don't currently have any checks (it's not easy in the general
> case... though I think I might now have some ideas on how to
> get at least _some_ type of checking in place)
> Paul
>> Hi Fred, when I view this in postx I get the impression that there
>> are two nested meshes there...  One associated with the sphere, the
>> other looks like a std. periodic box ?  (box first, sphere second)
>> What tipped me off is that your number of elements is not divisible
>> by 6, and that when I selected to plot face 5, some faces that are
>> not part of the std. spherical mesh configuration showed up.
>> Checking further...
>> Paul
>>> Dear NEKs,
>>> I'm trying to compute periodic channel flow around a sphere. The grid I
>>> made with Prenek (SPHERICAL MESH). But the run is always crashing after
>>> some timesteps. I tried with different meshes and configurations but it
>>> never run through...
>>> I attached the .rea, .usr, SIZE and output files.
>>> Best, Fred
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
