[Nek5000-users] to Hank
Wed Apr 21 12:47:22 CDT 2010
Yes the *.f???? is supported by VisIt.
Your file template is wrong. Try again with:
filetemplate:  c203d%01d.f%04d
Stefan
On Apr 21, 2010, at 7:42 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Hello Hank,
> Is the new *.f???? format supported by Visit?  I can read it in without
> an error, but there is no data, not even a mesh is present.
> The data file is:
> http://tetra.fluid.tuwien.ac.at/fmuldoo/engineering-marangoni-flows/sim2/sim1/sim1/c203d0.f0001
> I use the following meta data file:
> NEK5000
> version: 1.0
> filetemplate:  c203d0.f%04d
> firsttimestep: 1
> numtimesteps: 1
> Cheers,
> Frank
> On Wed, 2010-04-21 at 10:08 -0700, nek5000-users at lists.mcs.anl.gov
> wrote:
>>> I am looking for a way to tell NEK to switch between writing out *.fld??
>>> and *.f???? files.  Also, Visit has problems with (temporal) sequences
>>> of *.fld?? files that exceed 99.  a.fld01 ... a.fld99 is OK, but
>>> a.fld100 doesn't fit into the metadata format.  Can the number of digits
>>> in the names of the *.fld?? files be increased.
>> Hi Frank,
>> I'll look into "a.fld100" support for VisIt.  Someone else will need
>> to respond to the question about switching between .fld and .f????
>> files.
>> Best,
>> Hank
>> Nek5000-users mailing list
>> Nek5000-users at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> Frank Herbert Muldoon, Ph.D. Mechanical Engineering
> Technische Universität Wien (Technical University of Vienna)
> Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
> Mechanics and Heat Transfer)
> Resselgasse 3
> 1040 Wien
> Tel: +4315880132232
> Fax: +4315880132299
> Cell:+436765203470
> fmuldoo (skype)
> http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
