[Nek5000-users] to Hank
Wed Apr 21 12:42:32 CDT 2010
Hello Hank,
Is the new *.f???? format supported by Visit?  I can read it in without
an error, but there is no data, not even a mesh is present.
The data file is:
http://tetra.fluid.tuwien.ac.at/fmuldoo/engineering-marangoni-flows/sim2/sim1/sim1/c203d0.f0001
I use the following meta data file:
NEK5000
version: 1.0
filetemplate:  c203d0.f%04d
firsttimestep: 1
numtimesteps: 1
Cheers,
Frank
On Wed, 2010-04-21 at 10:08 -0700, nek5000-users at lists.mcs.anl.gov
wrote:
> > I am looking for a way to tell NEK to switch between writing out *.fld??
> > and *.f???? files.  Also, Visit has problems with (temporal) sequences
> > of *.fld?? files that exceed 99.  a.fld01 ... a.fld99 is OK, but
> > a.fld100 doesn't fit into the metadata format.  Can the number of digits
> > in the names of the *.fld?? files be increased.
> Hi Frank,
> I'll look into "a.fld100" support for VisIt.  Someone else will need
> to respond to the question about switching between .fld and .f????
> files.
> Best,
> Hank
> Nek5000-users mailing list
Frank Herbert Muldoon, Ph.D. Mechanical Engineering
Technische Universität Wien (Technical University of Vienna)
Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
Mechanics and Heat Transfer)
Resselgasse 3
1040 Wien
Tel: +4315880132232
Fax: +4315880132299
Cell:+436765203470
fmuldoo (skype)
http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
