[Nek5000-users] Visit and NEK files
Wed Apr 21 12:17:16 CDT 2010
In general you can specify the output/input format using param(67) and param(66).
Use a positive number (including 0) for the new binary *.f???? format. A negative number is for ASCII fld-files. To get the old binary fld format set param(.) = 4 in the .usr file. You cannot use the .rea in this case!
Stefan
On Apr 21, 2010, at 7:01 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Hello all,
> I am looking for a way to tell NEK to switch between writing out *.fld??
> and *.f???? files.  Also, Visit has problems with (temporal) sequences
> of *.fld?? files that exceed 99.  a.fld01 ... a.fld99 is OK, but
> a.fld100 doesn't fit into the metadata format.  Can the number of digits
> in the names of the *.fld?? files be increased.
> Cheers,
> Frank
> Frank Herbert Muldoon, Ph.D. Mechanical Engineering
> Technische Universität Wien (Technical University of Vienna)
> Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
> Mechanics and Heat Transfer)
> Resselgasse 3
> 1040 Wien
> Tel: +4315880132232
> Fax: +4315880132299
> Cell:+436765203470
> fmuldoo (skype)
> http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
> Nek5000-users mailing list
