[Nek5000-users] Visit and NEK 3D data
Wed Apr 21 07:09:44 CDT 2010
Note the *.f???? is the recommended data format for production runs!
A lot of features and optimizations are only available for the *.f???? format.
The only problem is that some tools like postx,prex do not support the *.f???? format. However you can use NEK to convert one format into another one.
Stefan
On Apr 21, 2010, at 2:05 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Frank,
> the .f.... format is associated with our parallel i/o, but
> also works in serial.   However, it doesn't work w/ postx
> (if you're using that...)
> Paul
> On Wed, 21 Apr 2010, nek5000-users at lists.mcs.anl.gov wrote:
>> Hi Stefan,
> I am not sure exactly what that format "*.f????" is.  In "usrdat2" I
> have:
>      param(66) = 4.   ! These give the std nek binary i/o and are
>      param(67) = 4.   ! good default values
> There are two different binary formats?
> Cheers,
> Frank
> On Wed, 2010-04-21 at 13:54 +0200, nek5000-users at lists.mcs.anl.gov
> wrote:
>> Hi,
>> is there a reason why you don't want to use the *.f???? binary format?
>> Stefan
>> On Apr 21, 2010, at 1:52 PM, nek5000-users at lists.mcs.anl.gov wrote:
>> > Hello all,
>> > > I am running into a problem with Visit and NEK 3D data files.  Visit
>> > (version 1.12.2) reads them in, but the mesh is all jumbled up.  If
>> > anyone could try Visit on this file, I'd be grateful, perhaps there is
>> > some setting in Visit that I overlooked. > > The data file (4MB) is:
>> > http://tetra.fluid.tuwien.ac.at/fmuldoo/engineering-marangoni-flows/sim2/sim1/sim1/c203d.fld01
>> > > I use the following meta data file:
>> > NEK5000
>> > version: 1.0
>> > filetemplate:  c203d.fld%02d
>> > firsttimestep: 2
>> > numtimesteps: 1
>> > > > Cheers,
>> > Frank
>> > > > -- > Frank Herbert Muldoon, Ph.D. Mechanical Engineering
>> > Technische Universität Wien (Technical University of Vienna)
>> > Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
>> > Mechanics and Heat Transfer)
>> > Resselgasse 3
>> > 1040 Wien
>> > Tel: +4315880132232
>> > Fax: +4315880132299 > Cell:+436765203470
>> > fmuldoo (skype)
>> > http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
>> > > _______________________________________________
>> > Nek5000-users mailing list
>> > Nek5000-users at lists.mcs.anl.gov
>> > https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> Resselgasse 3
> 1040 Wien
> Tel: +4315880132232
> Fax: +4315880132299 Cell:+436765203470
> fmuldoo (skype)
> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users_______________________________________________
