[Nek5000-users] Visit and NEK 3D data
Wed Apr 21 07:05:16 CDT 2010
Hi Frank,
the .f.... format is associated with our parallel i/o, but
also works in serial.   However, it doesn't work w/ postx
(if you're using that...)
Paul
On Wed, 21 Apr 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Stefan,
I am not sure exactly what that format "*.f????" is.  In "usrdat2" I
have:
       param(66) = 4.   ! These give the std nek binary i/o and are
       param(67) = 4.   ! good default values
There are two different binary formats?
Cheers,
Frank
On Wed, 2010-04-21 at 13:54 +0200, nek5000-users at lists.mcs.anl.gov
wrote:
> Hi,
> is there a reason why you don't want to use the *.f???? binary format?
> Stefan
> On Apr 21, 2010, at 1:52 PM, nek5000-users at lists.mcs.anl.gov wrote:
> > Hello all,
> > I am running into a problem with Visit and NEK 3D data files.  Visit
> > (version 1.12.2) reads them in, but the mesh is all jumbled up.  If
> > anyone could try Visit on this file, I'd be grateful, perhaps there is
> > some setting in Visit that I overlooked.
> > The data file (4MB) is:
> > http://tetra.fluid.tuwien.ac.at/fmuldoo/engineering-marangoni-flows/sim2/sim1/sim1/c203d.fld01
> > I use the following meta data file:
> > NEK5000
> > version: 1.0
> > filetemplate:  c203d.fld%02d
> > firsttimestep: 2
> > numtimesteps: 1
> > Cheers,
> > Frank
> > Frank Herbert Muldoon, Ph.D. Mechanical Engineering
> > Technische Universität Wien (Technical University of Vienna)
> > Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
> > Mechanics and Heat Transfer)
> > Resselgasse 3
> > 1040 Wien
> > Tel: +4315880132232
> > Fax: +4315880132299
> > Cell:+436765203470
> > fmuldoo (skype)
> > http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
> > _______________________________________________
> > Nek5000-users mailing list
> > Nek5000-users at lists.mcs.anl.gov
> > https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
Resselgasse 3
1040 Wien
Tel: +4315880132232
Fax: +4315880132299
Cell:+436765203470
fmuldoo (skype)
