[Nek5000-users] *.fld files to ...
Mon Apr 19 11:06:58 CDT 2010
Hi Hank,
welcome to the NEK5000 community :)
It's good to have a real viz-expert onboard!
Cheers,
Stefan
On Apr 19, 2010, at 6:03 PM, nek5000-users at lists.mcs.anl.gov wrote:
> Hi Frank,
> It is possible to automate the Exports through VisIt.  I can help you
> with a script if you'd like.  That said, as Stefan points out, the
> TecPlot writer is limited.
> Best,
> Hank
> On Mon, Apr 19, 2010 at 8:57 AM,  <nek5000-users at lists.mcs.anl.gov> wrote:
>> Hi Stefan,
>> Thanks.  I had tried that.  This translator appears to be a fairly rough
>> attempt to output data in Tecplot's format.  It at times writes out
>> files that Tecplot cannot read.  In addition, if dealing with temporal
>> data, there appears to be no way to write out the data at each time step
>> to a single Tecplot file.  Therefore, one would need to do this
>> (exporting through the menus) for every file at every time step.
>> Cheers,
>> Frank
>> On Mon, 2010-04-19 at 17:34 +0200, nek5000-users at lists.mcs.anl.gov
>> wrote:
>>> Frank,
>>> read your data into VisIt and use the export option.
>>> I don't recall exactly what output formats they support but there are quite a few.
>>> Stefan
>>> On Apr 19, 2010, at 5:30 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>> Hello all,
>>>> Does anyone know of a way to translate *.fld files to a different format
>>>> (perhaps such as HDF, CGNS, Plot3D etc.)?
>>>> Cheers,
>>>> Frank
>>>> Frank Herbert Muldoon, Ph.D. Mechanical Engineering
>>>> Technische Universität Wien (Technical University of Vienna)
>>>> Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
>>>> Mechanics and Heat Transfer)
>>>> Resselgasse 3
>>>> 1040 Wien
>>>> Tel: +4315880132232
>>>> Fax: +4315880132299
>>>> Cell:+436765203470
>>>> fmuldoo (skype)
>>>> http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
>>>> _______________________________________________
>>>> Nek5000-users mailing list
>>>> Nek5000-users at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>> Resselgasse 3
>> 1040 Wien
>> Tel: +4315880132232
>> Fax: +4315880132299
>> Cell:+436765203470
>> fmuldoo (skype)
