[Nek5000-users] *.fld files to ...
Mon Apr 19 11:03:39 CDT 2010
Hi Frank,
It is possible to automate the Exports through VisIt.  I can help you
with a script if you'd like.  That said, as Stefan points out, the
TecPlot writer is limited.
Best,
Hank
On Mon, Apr 19, 2010 at 8:57 AM,  <nek5000-users at lists.mcs.anl.gov> wrote:
> Hi Stefan,
> Thanks.  I had tried that.  This translator appears to be a fairly rough
> attempt to output data in Tecplot's format.  It at times writes out
> files that Tecplot cannot read.  In addition, if dealing with temporal
> data, there appears to be no way to write out the data at each time step
> to a single Tecplot file.  Therefore, one would need to do this
> (exporting through the menus) for every file at every time step.
> Cheers,
> Frank
> On Mon, 2010-04-19 at 17:34 +0200, nek5000-users at lists.mcs.anl.gov
> wrote:
>> Frank,
>> read your data into VisIt and use the export option.
>> I don't recall exactly what output formats they support but there are quite a few.
>> Stefan
>> On Apr 19, 2010, at 5:30 PM, nek5000-users at lists.mcs.anl.gov wrote:
>> > Hello all,
>> > Does anyone know of a way to translate *.fld files to a different format
>> > (perhaps such as HDF, CGNS, Plot3D etc.)?
>> > Cheers,
>> > Frank
>> > Frank Herbert Muldoon, Ph.D. Mechanical Engineering
>> > Technische Universität Wien (Technical University of Vienna)
>> > Inst. f. Strömungsmechanik und Wärmeübertragung (Institute of Fluid
>> > Mechanics and Heat Transfer)
>> > Resselgasse 3
>> > 1040 Wien
>> > Tel: +4315880132232
>> > Fax: +4315880132299
>> > Cell:+436765203470
>> > fmuldoo (skype)
>> > http://tetra.fluid.tuwien.ac.at/fmuldoo/public_html/webpage/frank-muldoon.html
>> > _______________________________________________
>> > Nek5000-users mailing list
>> > Nek5000-users at lists.mcs.anl.gov
>> > https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
> Resselgasse 3
> 1040 Wien
> Tel: +4315880132232
> Fax: +4315880132299
> Cell:+436765203470
> fmuldoo (skype)
