[Nek5000-users] PN/PN and usrdiv
Fri Apr 9 08:46:12 CDT 2010
Hi Markus,
In your first sets of tests, did you notice that your
peak speed went up dramatically ?  ...  In most of my
cases I notice that the outflow velocity is "red" (i.e.,
fast) because of this condition.
I'll check this w/ PnPn.
Paul
On Fri, 9 Apr 2010, nek5000-users at lists.mcs.anl.gov wrote:
> Hi,
> since I switched the pressure scheme from P_N/P_N-2 to PN/PN, as recommended
> by an earlier email, I have divergence trouble (simulation crashes) at the
> outflow, were a stabilization technique as in examples "peris" and "jet" is
> in place (adding divergence via usrdiv).
> I spent a long time trying to fix this (several test runs with increased
> outflow normal element length, increased divergence magnitude, mesh
> deformation to nozzle shape, which avoids crashing but has an adverse effect
> on the upstream flow,...) but I am becoming suspicious that usrdiv is just
> not used in PN/PN.
> Is that true? If so, how to fix it?
> Thanks,
> Markus
> Nek5000-users mailing list
