[Nek5000-users] Seg. fault in running a backward facing step case.
Fri Apr 9 09:33:18 CDT 2010
Hello,
I am trying to simulate flow in a 3D backward facing step (BFS) geometry.
I have attached the *.box file and n2to3.in file that I use to create the
3D geometry. For reference logfile, *.rea and *.usr files are attached.
The code is compiled with GNU compiler and OpenMPI. The code is compiled
for 16 processors and compiler.out file is attached as well.
When I run the code, I get a seg. fault. After running the "gdb" tool on
the core.* file, I get the following output. I have attached the gdb
output file too.
Core was generated by `./nek5000'.
Program terminated with signal 11, Segmentation fault.
[New process 7652]
#0  0x0000000000488768 in chcopy_ ()
3D BFS geometry has a wall at the bottom and symmetry b.c. at the top. But
if I change the top b.c. with wall the simulation works. For reference I
have attached the job output file.
Initially, I thought the problem was with memory limitations on my cluster
for a bigger geometry. So I tried a smaller geometry, but I still kept
getting seg. faults.
Help with solving this problem will be greatly appreciated. And sorry for
attaching so many files.
Harish.
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100409/911c663f/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100409/911c663f/attachment-0001.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100409/911c663f/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100409/911c663f/attachment-0003.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100409/911c663f/attachment-0004.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100409/911c663f/attachment.o>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100409/911c663f/attachment-0005.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/nek5000-users/attachments/20100409/911c663f/attachment-0006.obj>
