[Nek5000-users] PN/PN and usrdiv
Fri Apr 9 15:33:48 CDT 2010
In addition to the issue that Stefan identified, it turns
out that the set_outflow_dist() routine in the .usr file
was dependent on zm2 (z coords on mesh2), which defined
only for Pn-Pn-2.
I've updated coef.f so that xm2 ym2 and zm2 are now defined
for both formulations and it seems that the outflow conditions
are now working.
Paul
On Fri, 9 Apr 2010, nek5000-users at lists.mcs.anl.gov wrote:
> I'll check into it this afternoon...
> Paul
>> Paul,
>> I think know why. We should not multiply usrdiv with the mass matrix
>> so just replace
>> call col3 (h1,usrdiv,bm1,ntot1)
>> call add2 (qtl,h1,ntot1)
>> by
>> call add2(qtl,usrdiv,ntot1)
>> at the beginning of plan4().
>> Unfortunately I don't have the time to test this fix.
>> Let me know if this works for you.
>> Stefan
>> On Apr 9, 2010, at 4:21 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>> Yes - I just checked and it's indeed not doing anything for
>>> Pn-Pn.
>>> I'll get to this by the end of the afternoon... should take
>>> minimal effort to repair I think.
>>> Sorry about this Markus.
>>> Paul
>>>> I have not used this feature for a while but usrdiv is used in plan4().
>>>> --- snip plan4.f ---
>>>> 40       ! add user defined divergence to qtl
>>>> 41       call col3 (h1,usrdiv,bm1,ntot1)
>>>> 42       call add2 (qtl,h1,ntot1)
>>>> --- snip plan4.f
>>>> Stefan
>>>> On Apr 9, 2010, at 1:49 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>> Hi,
>>>>> since I switched the pressure scheme from P_N/P_N-2 to PN/PN, as
>>>>> recommended by an earlier email, I have divergence trouble (simulation
>>>>> crashes) at the outflow, were a stabilization technique as in examples
>>>>> "peris" and "jet" is in place (adding divergence via usrdiv).
>>>>> I spent a long time trying to fix this (several test runs with increased
>>>>> outflow normal element length, increased divergence magnitude, mesh
>>>>> deformation to nozzle shape, which avoids crashing but has an adverse
>>>>> effect on the upstream flow,...) but I am becoming suspicious that
>>>>> usrdiv is just not used in PN/PN.
>>>>> Is that true? If so, how to fix it?
>>>>> Thanks,
>>>>> Markus
>>>>> _______________________________________________
>>>>> Nek5000-users mailing list
>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
