[Nek5000-users] endian problems
Thu Dec 3 09:20:21 CST 2009
That's great Stefan! Is this version available in the svn-system?
Quoting nek5000-users at lists.mcs.anl.gov:
> I was able to identify where the problems is. Yes you're right there
>  is bug in the latest repo version if you'll try to restart and you
> need to swap the bytes.
> Fixed it in my dev-version.
> #Stefan
> On Dec 3, 2009, at 2:13 PM, nek5000-users at lists.mcs.anl.gov wrote:
>> It turns out that the old version of the code hangs after a random
>> number of time steps, so I need the new version (r374) to work.
>>> Yes, the files were written out on a AMD Opteron Linux system.
>>> J
>>>> Ok and do you need to swap the bytes on Intrepid meaning is your
>>>>   restart data of small endian type?
>>>> On Dec 3, 2009, at 11:30 AM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>> It's a blahh??.f0001 file. (16 files)
>>>>> Johan
>>>>>> Is the restart data a .fld?? or a .f???? file?
>>>>>> #Stefan
>>>>>> On Dec 3, 2009, at 11:08 AM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>>> Hi again,
>>>>>>> It seems to work when I use a slightly older version of the code. There
>>>>>>> was apparently a change in ic.f where the restart data was read in
>>>>>>> ('Reading restart data..' --> 'Reading checkpoint data..').
>>>>>>> Johan
>>>>>>> Johan Ohlsson
>>>>>>> Department of Mechanics, KTH
>>>>>>> SE-100 44, Stockholm, Sweden
>>>>>>> Phone: +46 8 7906876
>>>>>>> E-mail: johan at mech.kth.se
>>>>>>> _______________________________________________
>>>>>>> Nek5000-users mailing list
>>>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>>>> Johan Ohlsson
>>> This message was sent using IMP, the Internet Messaging Program.
