[Nek5000-users] endian problems
Thu Dec 3 09:07:46 CST 2009
I was able to identify where the problems is. Yes you're right there is bug in the latest repo version if you'll try to restart and you need to swap the bytes.
Fixed it in my dev-version.
#Stefan
On Dec 3, 2009, at 2:13 PM, nek5000-users at lists.mcs.anl.gov wrote:
> It turns out that the old version of the code hangs after a random number of time steps, so I need the new version (r374) to work.
> Quoting nek5000-users at lists.mcs.anl.gov:
>> Yes, the files were written out on a AMD Opteron Linux system.
>> J
>>> Ok and do you need to swap the bytes on Intrepid meaning is your   restart data of small endian type?
>>> On Dec 3, 2009, at 11:30 AM, nek5000-users at lists.mcs.anl.gov wrote:
>>>> It's a blahh??.f0001 file. (16 files)
>>>> Johan
>>>>> Is the restart data a .fld?? or a .f???? file?
>>>>> #Stefan
>>>>> On Dec 3, 2009, at 11:08 AM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>> Hi again,
>>>>>> It seems to work when I use a slightly older version of the code. There
>>>>>> was apparently a change in ic.f where the restart data was read in
>>>>>> ('Reading restart data..' --> 'Reading checkpoint data..').
>>>>>> Johan
>>>>>> Johan Ohlsson
>>>>>> Department of Mechanics, KTH
>>>>>> SE-100 44, Stockholm, Sweden
>>>>>> Phone: +46 8 7906876
>>>>>> E-mail: johan at mech.kth.se
>>>>>> _______________________________________________
>>>>>> Nek5000-users mailing list
>>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>>> Johan Ohlsson
>> This message was sent using IMP, the Internet Messaging Program.
