[Nek5000-users] endian problems
Thu Dec 3 11:46:31 CST 2009
I will submit it after doing some tests. Unfortunately I am quite busy these days so I don't think it will be available before next week.
#Stefan
On Dec 3, 2009, at 4:20 PM, nek5000-users at lists.mcs.anl.gov wrote:
> That's great Stefan! Is this version available in the svn-system?
> Quoting nek5000-users at lists.mcs.anl.gov:
>> I was able to identify where the problems is. Yes you're right there  is bug in the latest repo version if you'll try to restart and you  need to swap the bytes.
>> Fixed it in my dev-version.
>> #Stefan
>> On Dec 3, 2009, at 2:13 PM, nek5000-users at lists.mcs.anl.gov wrote:
>>> It turns out that the old version of the code hangs after a random  number of time steps, so I need the new version (r374) to work.
>>>> Yes, the files were written out on a AMD Opteron Linux system.
>>>> J
>>>>> Ok and do you need to swap the bytes on Intrepid meaning is your    restart data of small endian type?
>>>>> On Dec 3, 2009, at 11:30 AM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>> It's a blahh??.f0001 file. (16 files)
>>>>>> Johan
>>>>>>> Is the restart data a .fld?? or a .f???? file?
>>>>>>> #Stefan
>>>>>>> On Dec 3, 2009, at 11:08 AM, nek5000-users at lists.mcs.anl.gov wrote:
>>>>>>>> Hi again,
>>>>>>>> It seems to work when I use a slightly older version of the code. There
>>>>>>>> was apparently a change in ic.f where the restart data was read in
>>>>>>>> ('Reading restart data..' --> 'Reading checkpoint data..').
>>>>>>>> Johan
>>>>>>>> Johan Ohlsson
>>>>>>>> Department of Mechanics, KTH
>>>>>>>> SE-100 44, Stockholm, Sweden
>>>>>>>> Phone: +46 8 7906876
>>>>>>>> E-mail: johan at mech.kth.se
>>>>>>>> _______________________________________________
>>>>>>>> Nek5000-users mailing list
>>>>>>>> Nek5000-users at lists.mcs.anl.gov
>>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/nek5000-users
>>>>>> Johan Ohlsson
>>>> This message was sent using IMP, the Internet Messaging Program.
